Discuss
Whirlpool oven bottom removal
 in
I'm trying to replace the oven ignitor but can't get oven bottom out, I removed the two screws
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool oven bottom removal
  #1 (permalink)
Old 06-30-2008, 04:13 PM
Paul@buckleyphotos.com Paul@buckleyphotos.com is offline
Junior Member
Paul@buckleyphotos.com is on a distinguished road
Default Whirlpool oven bottom removal
Model Number: sf367peyw1   Brand: Whirlpool   Age: More than 10 years
I'm trying to replace the oven ignitor but can't get oven bottom out, I removed the two screws in the back of the oven bottom and I can get it to pivot forward but that's it. Any secret to getting it out?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-01-2008, 04:47 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Lift the back of the oven bottom and slide it outward to release the front of the oven bottom from the frame and then remove it.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 07-02-2008, 07:38 AM
Junior Member
Default
Thanks Gene, that did the trick
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas oven-no bottom burner lwright99@alltel.net Oven Repair (including Ranges and Cooktops) 6 03-29-2008 12:04 PM
Oven door removal suddeth Oven Repair (including Ranges and Cooktops) 0 01-24-2008 12:09 PM
Bottom Oven Not Working, Top Works TammyA Oven Repair (including Ranges and Cooktops) 0 12-31-2007 09:53 PM
oven control removal ericnor Oven Repair (including Ranges and Cooktops) 1 11-10-2007 09:06 PM
Whirlpool front cover removal John Dryer Repair 0 08-10-2007 06:17 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
