The touchpad on my jenn air range is not working properly. The oven controls (bake, broil,convect bake, convect roast) clean, cancel, and numbers 1 through 6 do not work. The clock works, but it will go blank every so often when the right rear burner is being lit. To get the clock to work again I have to disconnect the clock from the power by removing the connections and reconnecting them. I took the range apart looking for a short but could not find any. Is it the touchpad causing the problem or the relay board? Is there a service manual or technical sheet available for this range? Thank you for your help.
The model number you posted does not come up. Verify and repost it.
