Discuss
Oven is making beep music and showing error codes F1 and F0
 in
This is a Dacor double oven (top convection) we bought in 1995. Straight and to the point: Oven turns off
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven is making beep music and showing error codes F1 and F0
  #1 (permalink)
Old 09-05-2007, 10:58 PM
sandmn3 sandmn3 is offline
Junior Member
sandmn3 is on a distinguished road
Default Oven is making beep music and showing error codes F1 and F0
Model Number: cps227w   Brand: Dacor   Age: More than 10 years
Oven turns off during preheating, beeps inconsistently and shows error codes F0 and F1. Had a technician come by and say the ERC is bad and needed to be changed. I bought a new ERC and installed it and am still having the same problem.
Per Dacor Owners's Manual:
F0 - Touchpad being stuck in a depressed position
F1 - Element relay circuit failure
I don't think it is the touchpad, since there is a new ERC, but does the F1 mean that one of the relay boards is bad and needs replacing? and if so, how can I test it to make sure or to find out which one needs replacing? Or, could the ERC be defective.
Thanks in advance for your help.
---Brad
Related Models
Whirlpool CPT08D1A1
Whirlpool CPT08DA1A
Whirlpool CPT18C2A1
Crosley CR1100K Mwave - Cntrtp / Stand Alone
Crosley CR1100KG Mwave - Cntrtp / Stand Alone
Crosley CR1100KW Mwave - Cntrtp / Stand Alone
Amana CR14 Misc / Accessory
Amana CR14L Misc / Accessory
Crosley CR151K Mwave - Cntrtp / Stand Alone
Crosley CR151KWH Mwave - Cntrtp / Stand Alone
Crosley CR151WH Mwave - Cntrtp / Stand Alone
Crosley CR153K Mwave - Cntrtp / Stand Alone
Crosley CR154K Mwave - Cntrtp / Stand Alone
Crosley CR154KWH Mwave - Cntrtp / Stand Alone
Whirlpool CR18PKXRS00 Refrigerator
Whirlpool CR18PKXRS01 Refrigerator
Jenn-Air CR220B Surf Cont Panel Unit - Ddft Ele
Jenn-Air CR220B-C Surf Cont Panel Unit - Ddft Ele
Jenn-Air CR220W Surf Cont Panel Unit - Ddft Ele
Jenn-Air CR220W-C Surf Cont Panel Unit - Ddft Ele
Thermador CR30
Frigidaire CR302VP2D03 Frg(v1) / Gas Range
Frigidaire CR302VP2W03 Frg(v2) / Gas Range
Thermador CR30W
Thermador CR36
Thermador CR36W
Crosley CR4100 Mwave - Cntrtp / Stand Alone
Crosley CR4200 Mwave - Cntrtp / Stand Alone
Crosley CR4614K Mwave - Cntrtp / Stand Alone
Crosley CR4614KWH Mwave - Cntrtp / Stand Alone
Crosley CR464B Mwave - Cntrtp / Stand Alone
Magic Chef CRB21EA-3A Ref - Top Mount
Magic Chef CRB21EN-3A Ref - Top Mount
Magic Chef CRB21EY-3A Ref - Top Mount
Magic Chef CRB22EA-3AI Ref - Top Mount/ I&W
Magic Chef CRB22EN-3AI Ref - Top Mount/ I&W
Magic Chef CRB22EY-3AI Ref - Top Mount/ I&W
Amana CRC10T Commercial Microwaves
Amana CRC10T2 Commercial Microwaves
Amana CRC12T Commercial Microwaves
Amana CRC12T2 Commercial Microwaves
Amana CRC18T2 Commercial Microwaves
Amana CRC18T2OG Commercial Microwaves
Amana CRC18T2OG2  Commercial Microwaves
Amana CRC18T2SD Commercial Microwaves
Amana CRC21T2 Commercial Microwaves
Amana CRC21T2RL Commercial Microwaves
Amana CRC21T2RL2  Commercial Microwaves
Magic Chef CRC22EA-3AW Ref - SXS/I&W
Magic Chef CRC22EN-3AW Ref - SXS/I&W
Magic Chef CRC22EY-3AW Ref - SXS/I&W
Magic Chef CRC24EA-3AI Ref - SXS/I&W
Magic Chef CRC24EN-3AI Ref - SXS/I&W
Magic Chef CRC24EY-3AI Ref - SXS/I&W
Amana CRC510T2 Commercial Microwaves
Amana CRC514D Commercial Microwaves
Amana CRC514T2 Commercial Microwaves
Amana CRC518D Commercial Microwaves
Amana CRC518T2 Commercial Microwaves
Amana CRC8 Commercial Microwaves
Amana CRCR-7 Mwave - Mounted Over Range/wo
Amana CRCR8 Walloven - Std Mwave Ele
Magic Chef CRD22AY-3A Ref - Sxs
Magic Chef CRD22EA-3A Ref - Sxs
Magic Chef CRD22EN-3A Ref - Sxs
Magic Chef CRD22EY-3A Ref - Sxs
Maytag CRE0305ACW Range - F/s Std Ele
Maytag CRE0655ACW Range - S/c F/s Ele
Maytag CRE0775ACW Range - S/c F/s Ele
Amana CRE14 Misc / Accessory
Maytag CRE200 Range - F/s Std Ele
Maytag CRE200B Range - F/s Std Ele
Maytag CRE300 Range - F/s Std Ele
Maytag CRE300B Range - F/s Std Ele
Maytag CRE305 Range - F/s Std Ele
Maytag CRE350 Range - F/s Std Ele
Maytag CRE350B Range - F/s Std Ele
Maytag CRE355 Range - F/s Std Ele
Maytag CRE383 Range - F/s Std Ele
Maytag CRE400 Range - F/s Std Ele
Maytag CRE400B Range - F/s Std Ele
Maytag CRE500 Range - F/s Std Ele
Maytag CRE500B Range - F/s Std Ele
Maytag CRE600 Range - F/s Std Ele
Maytag CRE600B Range - F/s Std Ele
Maytag CRE650 Range - F/s Std Ele
Maytag CRE655 Range - S/c F/s Ele
Maytag CRE682 Range - S/c F/s Ele
Maytag CRE682B Range - S/c F/s Ele
Maytag CRE683 Range - S/c F/s Ele
Maytag CRE700 Range - S/c F/s Ele
Maytag CRE750 Range - S/c F/s Ele
Maytag CRE7500ACL Range - F/s Std Ele
  #2 (permalink)
Old 09-05-2007, 11:36 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Hi sandmn3
It is pretty simple to find out exactly what is the problem: the touch pad or the control board. Remove the power from the oven, open the control panel and unplug the touch pad ribbon from the control board. Replace the control panel, restore the power and monitor the oven for a few hours.
If no error codes shown up, the problem is the shorted pads on the touch pad. If you see the error codes again then the ERC you bought is defective.
- The part number for the new touch pad (aka membrane switch or bezel)is AP3395080
Good luck.
__________________
  #3 (permalink)
Old 10-05-2008, 03:47 PM
Michael D Michael D is offline
Junior Member
Michael D is on a distinguished road
Default Magic Chef model 6498vta ser#14004916ks
Oven was purchased in 1994. Since then we have replaced the timer three times - twice in the last 90 days. The last one only lasted 8 hrs. It works for a while then starts beeping and displays an F1 code. Repairman is stumped. Any ideas?
  #4 (permalink)
Old 10-06-2008, 03:54 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Michael,
I do not think the problem is a bad timer. Most likely it is a shorted pad(s) on the membrane switch.
In order to provide the right part number for the membrane switch I need the color of it.
Here are the break down diagrams for the Magic Chef range Model 6498VTA
__________________
  #5 (permalink)
Old 10-07-2008, 12:17 PM
lazermule lazermule is offline
Junior Member
lazermule is on a distinguished road
Default
Quote:
Originally Posted by Gene View Post
Hi Michael,
I am having a similar issue with my Amana. Started beeping and was selecting the timer on its own like someone was standing there hitting the timer button. I unplugged the pad and restored power and the beeping went away. A new $100 membrane pad is on the way...
LAZER
  #6 (permalink)
Old 10-07-2008, 04:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Lazer,
Most likely the new membrane switch will solve the problem. Keep us posted.
__________________
  #7 (permalink)
Old 10-07-2008, 08:47 PM
Junior Member
Default
Hey Gene, Thanks for the reply and I'll be sure to keep you posted...
  #8 (permalink)
Old 12-26-2008, 08:09 PM
Andrew Mikesell Andrew Mikesell is offline
Junior Member
Andrew Mikesell is on a distinguished road
Default You promised to keep us posted
What finally happened to cure the F! Fault problem? I am going through the same beeping and F1 error. Thanks for any help you can put up
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven Error Codes Admin / APP Team Oven Repair (including Ranges and Cooktops) 125 11-07-2009 03:35 PM
maytag gemini F1-1,F3-1 codes ewenjo Oven Repair (including Ranges and Cooktops) 7 06-28-2008 05:47 PM
frigidaire failt codes Ruben Lucero Oven Repair (including Ranges and Cooktops) 1 08-10-2007 05:02 PM
Oven oesn't bake/heat and displays a "FS" error message jnymdnyt Oven Repair (including Ranges and Cooktops) 5 08-06-2007 07:36 PM
Only 8's showing on the erc display BruceL Oven Repair (including Ranges and Cooktops) 1 07-22-2007 11:20 PM
