When I turn the oven on will not stop preheating... If I cancel out bake and restart bake it will cool down to the set temp, then the elements will come on and stay on till I cancel again. Think it is the controler. Ordered a new controler part number W10108220 which is the one Sears directed me to buy... the connectors are not in the right place! Is it the controler?? Should I try to change the locations of the wires in the connector of the new board? Attempt to exchange the new controler for a different part # if so can you help? Or just stop baking?:mad:
Tks for your help
Les
