| » oven door hinge maytag |
Model Number: crg9800aae Brand: Maytag Age: More than 10 years
I need to replace the oven door hinge on my maytag crg9800aae. I took off the door and don't know how to remove the old hinges. Can anyone help with instructions?
I found that I need to take off the outer panel to access the hinge. To get at the screws I lifted the cook top but bent the gas line going to one burner causing it crack. Is there a way to raise the cook top without bending the sealed burner lines? Seems like I should be able to raise the cooktop and leave the burners alone? Now that I need to replace the cracked line can I just replace the one that cracked or do I need to replace the entire assembly? ts Ads By Google Related Models Last edited by tntsul : 05-02-2010 at 06:34 AM. |
| Display Modes | |
| oven door hinge | michaelmag | Oven Repair (including Ranges and Cooktops) | 33 | 10-29-2011 07:46 PM |
| oven door hinge/spring | dartchef | Oven Repair (including Ranges and Cooktops) | 0 | 11-02-2009 08:40 PM |
| Maytag Door Hinge Replacement | Alvin J | Oven Repair (including Ranges and Cooktops) | 0 | 10-07-2009 02:19 PM |
| Front Loader: How to reverse door swing / right hinge to left hinge | Three3walkers | Washer Repair | 3 | 05-31-2009 04:14 PM |
| oven door hinge broke,so did hinge post for top | Melodygmd | Oven Repair (including Ranges and Cooktops) | 1 | 12-30-2008 04:32 PM |
