My Whirlpool oven GBS307PDQ7 has the following symptoms:
1. air vent runs constantly 2. preheat clock does not display (no countdown) 3. does not heat in bake mode (only very low level heat) 4. when lock is applied, will not unlock unless power is shut off
I appreciate any suggestions. My assumption is the microcomputer.
Thanks-
Bradd, Your diagnosis sounds right. All these functions operated by the microcomputer. - The microcomputer Part number: AP3177932
Hi Gene,
Thanks very much for your response.
Bradd
