Recently I've been getting this error code "F-" no number just a dash (and the constant dinging sound). I have a list of standard codes, this one isn't listed. Usually occurs when using one of the cooktop heating elements. has started occuring about once a week. this morning occured twice in a ten minute period. Also noticed recently that an internal fan comes on sooner and stays on longer than in the past. Is this related? (last week the word "clean" appeared briefly on the control panel even though I hadn't activated the clean cycle. What is going on here? how do I test for problems?
Hi Boris,
I realize that this was posted over 3 years back, but I am seeing a similar problem with my Jenn Air oven displaying an F-dash error (F-) without a number, and I can't find information online about what this indicates. Were you ever able to sort out your problem?
Thanks, David
