My 5 burner Thermador Gas cooktop is only lighting intermittently. Other times the red indicator light does not come on and the cooktop can only be lit by a match. Sometimes it lights normally but the red indicator light will go out during cooking and the ignitors will then not work again to light other burners. Thanks :confused:
