| » Oven won't bake, only broil |
Model Number: RBS245TDB4 Brand: Whirlpool Age: 5 - 10 years
When I turn on the oven it used to start in Bake at 375. Now it starts in broil at 500 and the bake option won't work.\
Any ideas? This is a Whirlpool electronic controlled oven. |
Hi Ruth Ann
I need you to provide more specific description on what is going on with your oven when you try to use Bake mode. Also the model number you posted is not complete. It suppose to be something else after "D". Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Most likely the problem with your oven is a stuck broil pad on the key pad. In order to fix it the control panel has to be replaced.
- The part number for the white control panel AP2929132 - The part number for the black control panel AP2929131 - Here are the break down diagrams for the Whirlpool oven Model RBS305PDB6 Gene.
__________________
Ruth
Usually such decision should be based on the age and condition of the product. If it's still good and you like it, it might be worth to fix it. Good luck with the new one. Gene.
__________________
| Display Modes | |
| Bake and Broil elements not working | Janefield | Oven Repair (including Ranges and Cooktops) | 0 | 09-04-2007 03:29 PM |
| Oven oesn't bake/heat and displays a "FS" error message | jnymdnyt | Oven Repair (including Ranges and Cooktops) | 5 | 08-06-2007 07:36 PM |
| Bake Element and BAKE cycle not working | jeffman | Oven Repair (including Ranges and Cooktops) | 1 | 08-04-2007 11:18 PM |
| Oven Will Not Bake | tony | Oven Repair (including Ranges and Cooktops) | 6 | 08-01-2007 06:21 PM |
| Oven doesnt bake | ChrisF | Oven Repair (including Ranges and Cooktops) | 0 | 07-26-2007 06:25 PM |
