Discuss
Dual Element Burner Not Working
 in
Dual element burner only works for 1/2 of the burner. Both front burners are the same configuation. Took everything (
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Dual Element Burner Not Working
  #1 (permalink)
Old 04-24-2010, 04:43 PM
Junior Member
baffrjd is on a distinguished road
Default Dual Element Burner Not Working
Model Number: AER5722BAB   Brand: Amana   Age: 1 - 5 years
Dual element burner only works for 1/2 of the burner. Both front burners are the same configuation. Took everything ( rotary switch, rocker switch that changes burner from 6" burner size to 9" burner, burner element) from left front burner (side that does not work) and switched it out with the right front burner (known good side) . Everything works fine on the known good side. Continuity tests are all good.
At a complete loss as to what is going on.
Also checked for any signs of a bad wire, Insulation stripped, loose connection, etc. all good.
Anyone have any ideas?
Thanks in advance for suggestions as to what to look for next.
Ads By Google
Related Models
Amana AER5722BAB Range - S/c F/s Ele
Amana AER5722BAQ Range - S/c F/s Ele
Amana AER5722BAS Range - S/c F/s Ele
Amana AER5722BAW Range - S/c F/s Ele
Amana AER5722CAS Range - S/c F/s Ele
Amana AER5725QAB Range - S/c F/s Ele
Amana AER5725QAF Range - S/c F/s Ele
Amana AER5725QAN Range - S/c F/s Ele
Amana AER5725QAQ Range - S/c F/s Ele
Amana AER5725QAS Range - S/c F/s Ele
Amana AER5725QAW Range - S/c F/s Ele
Amana AER5735QAB Range - S/c F/s Ele
Amana AER5735QAF Range - S/c F/s Ele
Amana AER5735QAN Range - S/c F/s Ele
Amana AER5735QAQ Range - S/c F/s Ele
Amana AER5735QAS Range - S/c F/s Ele
Amana AER5735QAW Range - S/c F/s Ele
Amana AER5815RCB Range - S/c F/s Ele
Amana AER5815RCS Range - S/c F/s Ele
Amana AER5815RCW Range - S/c F/s Ele
Amana AER5845QAB Range - F/s Std Ele
Amana AER5845QAF Range - F/s Std Ele
Amana AER5845QAN Range - F/s Std Ele
Amana AER5845QAS Range - F/s Std Ele
Amana AER5845RAB Range - S/c F/s Ele
Amana AER5845RAS Range - S/c F/s Ele
Amana AER5845RAW Range - S/c F/s Ele
Amana AES1350BAW Range - S/c S/i Ele
General Electric AES15DAV1 Room air conditioner
General Electric AES18DAM1 Room air conditioner
General Electric AES23DAR1 Room air conditioner
Amana AES3540BAW Range - S/c S/i Gas
Amana AES3760BAB Range - S/c S/i Ele
Amana AES3760BAQ Range - S/c S/i Ele
Amana AES3760BAS Range - S/c S/i Ele
Amana AES3760BAW Range - S/c S/i Ele
Amana AES3760BCB Range - F/s Std Ele
Amana AES3760BCS Range - F/s Std Ele
Amana AES3760BCW Range - F/s Std Ele
Amana AES5730BAB Range - S/c S/i Ele
Amana AES5730BAF Range - S/c S/i Ele
Amana AES5730BAN Range - S/c S/i Ele
Amana AES5730BAS Range - S/c S/i Ele
Amana AET-480 Range - S/c S/i Ddraft Gas
Amana AET-480A Range - S/c S/i Ddraft Gas
Amana AET-480B Range - S/c S/i Ddraft Gas
Amana AET-480C Range - S/c S/i Ddraft Gas
General Electric AET05LHW1 Room air conditioner
General Electric AET05LJG1 Room air conditioner
General Electric AET05LJS1 Room air conditioner
General Electric AET05LJW1 Room air conditioner
Amana AEU-516 Range - S/c S/i Ddraft Gas
Amana AEU-516A Range - S/c S/i Ddraft Gas
Amana AEU-516C Range - S/c S/i Ddraft Gas
Amana AEU-516D Range - S/c S/i Ddraft Gas
Amana AEU-516E Range - S/c S/i Ddraft Gas
Amana AEU-516F Range - S/c S/i Ddraft Gas
Amana AEU-516G Range - S/c S/i Ddraft Gas
General Electric AEV24DJH1 Room air conditioner
General Electric AEV24DKH1 Room air conditioner
General Electric AEW05LJG1 Room air conditioner
General Electric AEW05LJS1 Room air conditioner
General Electric AEW05LJW1 Room air conditioner
General Electric AEW06LJG1 Room air conditioner
General Electric AEW06LJS1 Room air conditioner
General Electric AEW08AJS1 Room air conditioner
General Electric AEW10AJG1 Room air conditioner
General Electric AEW10AJS1 Room air conditioner
General Electric AEW24DHH1 Room air conditioner
General Electric AEW24DJH1 Room air conditioner
General Electric AEW24DKH1 Room air conditioner
Amana AEW3530DDB Walloven - S/c Ele
Amana AEW3530DDS Walloven - S/c Ele
Amana AEW3530DDW Walloven - S/c Ele
Amana AEW3630DDB Walloven - S/c Dbl Oven Ele
Amana AEW3630DDS Walloven - S/c Dbl Oven Ele
Amana AEW3630DDW Walloven - S/c Dbl Oven Ele
Amana AEW4530DDB Walloven - S/c Ele
Amana AEW4530DDQ Walloven - S/c Ele
Amana AEW4530DDS Walloven - S/c Ele
Amana AEW4530DDW Walloven - S/c Ele
Amana AEW4630DDB Walloven - S/c Dbl Oven Ele
Amana AEW4630DDQ Walloven - S/c Dbl Oven Ele
Amana AEW4630DDS Walloven - S/c Dbl Oven Ele
Amana AEW4630DDW Walloven - S/c Dbl Oven Ele
General Electric AEX08FAM1 Room air conditioner
Jenn-Air AEX918 Misc / Accessory
Thermador AF-7M
General Electric AF108FMP1 Room air conditioner
General Electric AF112DMW1 Room air conditioner
Admiral AF122 Freezer - Vertical
General Electric AF615DPE1 Room air conditioner
General Electric AF615DSE1 Room air conditioner
General Electric AF615DTE1 Room air conditioner
General Electric AF715DME1 Room air conditioner
General Electric AF812DMW1 Room air conditioner
General Electric AF812DNW1 Room air conditioner
General Electric AF908FMP3 Room air conditioner
General Electric AF908FMP4 Room air conditioner
General Electric AF908FSP1 Room air conditioner
General Electric AF908FTP1 Room air conditioner
General Electric AF908FWP1 Room air conditioner
General Electric AF910MBT1 Room air conditioner
General Electric AF910MST1 Room air conditioner
General Electric AF912AMW3 Room air conditioner
General Electric AF912AMW4 Room air conditioner
General Electric AF912ANW1 Room air conditioner
General Electric AF912ASW1 Room air conditioner
General Electric AF912DMW2 Room air conditioner
General Electric AF912DPW1 Room air conditioner
General Electric AF912DSW1 Room air conditioner
General Electric AF912WAD3 Room air conditioner
General Electric AF913WSD1 Room air conditioner
General Electric AF914WSE1 Room air conditioner
Whirlpool AFB07420
Amana AFB2534DEB Ref - Bottom Mounts
Amana AFB2534DEQ Ref - Bottom Mounts
Amana AFB2534DES Ref - Bottom Mounts
Amana AFB2534DEW Ref - Bottom Mounts
Amana AFB2534FES  Ref - Bottom Mounts
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag MER5770AAQ ... which dual element burner? dogfood Oven Repair (including Ranges and Cooktops) 0 04-10-2010 06:55 PM
Right p/n for the dual burner element b_x20852 Oven Repair (including Ranges and Cooktops) 0 01-20-2010 11:17 AM
Non-worKing dual element wporter Oven Repair (including Ranges and Cooktops) 0 12-26-2009 01:42 PM
Dacor electric stove dual burner element gratefulsouth Oven Repair (including Ranges and Cooktops) 0 11-13-2009 11:22 AM
Amana Dual element burner switch replacement deldillco Oven Repair (including Ranges and Cooktops) 0 03-14-2009 05:35 PM
