Discuss
dacor raised vent
 in
Where did you buy it from? $173 sounds too much. APP sell it for $145 and you can return it
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » dacor raised vent
  #21 (permalink)
Old 12-28-2012, 02:48 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Where did you buy it from? $173 sounds too much. APP sell it for $145 and you can return it later even if it was installed.
You'll never know how hard is to install it until you'll try and it should be covered under the parts warranty.
BTW, why not to return the part for refund and order it from APP?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #22 (permalink)
Old 05-09-2015, 12:03 PM
Junior Member
flipper003 is on a distinguished road
Default
I have the dacor rv30 and am having problems with the touch pad. Got a new one but could use some guidance on replacing it. To repeat post #14 - how do
you get the touch pad out of the top of the vent? There are no screws or tabs and nothing moves so there must be some magic way to take this apart to replace the touch board - I have the wiring all the way out from the unit with a string attached so I can pull it back through - just can't figure how get it out of the top part. Thanks for your help!
  #23 (permalink)
Old 08-04-2017, 06:51 AM
Junior Member
gfron1 is on a distinguished road
Default Dacor RV468 Hood - basic question
Apparently I'm keeping this very old thread alive. Hope someone is still out there to help.
I recently cleaned the inside of the hood by lifting and pulling out on the face plate/grill. Scrubbed years of grease off including the wire filters and put it all back together. When I lowered the hood the face plate fell into the range casing - meaning, it must not have been fully securely rested on the bottom bracket and when it was half way down the face plate slid outward and fell down into the cavity that the hood lowers into. I heard it. Cussed. Then raised the hood hoping for the best. No luck. i couldn't even see the grill/face plate, and now when i lower it the hood clearly hits the face plate and struggles to go down.
I don't want to burn out the motor so we're not touching anything until I know how to access the cavity. i see no obvious/easy way from the inside, but I'm betting that there might be a way to take the top off the hood that might help. Thoughts?
  #24 (permalink)
Old 08-11-2017, 11:05 AM
Junior Member
Default
Just kicking this dog in hopes of getting an answer. I'd really like to figure out how to fix this vent.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dacor Raised Vent Control Malfunction robertrice Oven Repair (including Ranges and Cooktops) 6 09-26-2014 10:56 AM
Dacor raised vent keypad removal sabraham Oven Repair (including Ranges and Cooktops) 1 02-18-2012 04:19 PM
Dacor ERV36 Raised Vent plamar53 Oven Repair (including Ranges and Cooktops) 0 11-12-2009 11:15 AM
Dacor Raised Vent - replacing main circuit board laphroiagh Oven Repair (including Ranges and Cooktops) 1 04-10-2009 09:46 PM
DACOR raised vent finish damage kell1791 Oven Repair (including Ranges and Cooktops) 0 03-05-2009 07:33 AM
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
