lexicarl
#1 Posted : Thursday, April 22, 2010 9:59:23 AM(UTC)
lexicarl
My Kenmore gas oven turned on in the off position. Now, when I need to use the oven, I have to turn it on & off several times until I see the flame glow. Once on, the temp can't be controlled. This leaves me to unplug the oven after each use. Any suggestions on the faulty part?
kayakcrzy
#2 Posted : Friday, April 23, 2010 4:14:21 AM(UTC)
kayakcrzy
What you need a new thermostat. The part # is WB20K8 The thermostat controls the oven. Tom ApplianceEducator.com - Parts
Kenmore gas oven will not stay at temperature (Oven Repair (including Ranges and Cooktops))
by kosgood 2/13/2021 8:51:55 AM(UTC)
Kenmore gas oven lights but won't get hot (Oven Repair (including Ranges and Cooktops))
by BonnieLC 5/14/2017 5:42:25 PM(UTC)
Kenmore gas oven won't heat up properly (Oven Repair (including Ranges and Cooktops))
by Black Cherry 3/27/2013 11:12:55 AM(UTC)
Kenmore Gas Oven Not cooking evening (Oven Repair (including Ranges and Cooktops))
by ghauptman 12/23/2012 6:47:06 AM(UTC)
Kenmore gas oven not lighting (Oven Repair (including Ranges and Cooktops))
by wingmaster12 11/11/2012 11:11:11 AM(UTC)
Kenmore Gas Oven works only sometimes (Oven Repair (including Ranges and Cooktops))
by Sixmenn 6/21/2010 4:48:50 AM(UTC)
Replacing round igniter on Kenmore gas oven (Oven Repair (including Ranges and Cooktops))
by techmonster 4/24/2010 11:55:57 AM(UTC)
Kenmore Gas Oven Control Panel replacement (Oven Repair (including Ranges and Cooktops))
by j.clayton 2/12/2010 12:35:45 PM(UTC)
by j.clayton 2/12/2010 12:34:17 PM(UTC)
Kenmore Gas oven burner too high ?!? (Oven Repair (including Ranges and Cooktops))
by 350rocket 10/24/2009 2:33:23 PM(UTC)
Kenmore gas oven doesn't ignite (Oven Repair (including Ranges and Cooktops))
by Jigger 8/24/2009 7:56:24 AM(UTC)
Kenmore gas oven will not turn ON (Oven Repair (including Ranges and Cooktops))
by skidoomxz99 8/20/2009 3:42:25 PM(UTC)
Broken Kenmore Gas oven (Oven Repair (including Ranges and Cooktops))
by jlraatz 3/18/2009 2:33:10 PM(UTC)
Kenmore gas oven display reads 'door' (Oven Repair (including Ranges and Cooktops))
by HandyAndy 3/5/2009 10:08:26 AM(UTC)
Oven Igniter For Kenmore Gas Oven (Oven Repair (including Ranges and Cooktops))
by rolivarez 12/1/2008 3:19:33 PM(UTC)
