Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Double oven top door spring broken (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/90041-double-oven-top-door-spring-broken.html)
Owenmart 04-19-2010 01:24 PM
Door spring just popped on upper oven door left side. Wont close so light remains on. Is there any special procedure or diagram to remove the door and replace with new spring hinge assembly? Thanks.
denman 04-21-2010 04:57 AM
Here is the parts breakdown
Replacement parts for JENN-AIR WW30430W Walloven - S/c Ele | AppliancePartsPros.com
Here is a manual which should help
http://www.servicematters.com/maytag...s/16010312.pdf
