Discuss
Gas wall oven will not light
 in
Burner will not light. The ignitor glows brightly, apparently the gas "safety valve" does not open. I have
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Gas wall oven will not light
  #1 (permalink)
Old 06-12-2008, 02:13 PM
Marrel Marrel is offline
Junior Member
Marrel is on a distinguished road
Default Gas wall oven will not light
Model Number: FGB24L2ASB   Brand: Frigidaire   Age: 1 - 5 years
Burner will not light. The ignitor glows brightly, apparently the gas "safety valve" does not open. I have ohm'd the safety valve, the coil has continuity, terminal to terminal; and does not show to be shorted. I understand the voltage from the ignitor is reduced - what voltage signal should I get to open the safety valve? Is there some way to bench test the safety valve and the ignitor so I know which to replace?
Related Models
Whirlpool FGP335EQ0
Whirlpool FGP335EW0
Whirlpool FGP335GN0
Whirlpool FGP335GN1
Whirlpool FGP335GQ0
Whirlpool FGP335GQ1
Whirlpool FGP335GW0
Whirlpool FGP335GW1
Whirlpool FGP335HN0
Whirlpool FGP335HQ0
Whirlpool FGP335HW0
Whirlpool FGP335VL0
Whirlpool FGP335VL1
Whirlpool FGP335VL2
Whirlpool FGP335VL3
Whirlpool FGP335VW0
Whirlpool FGP335VW1
Whirlpool FGP335VW2
Whirlpool FGP335VW3
Whirlpool FGP335YL0
Whirlpool FGP335YL1
Whirlpool FGP335YL2
Whirlpool FGP335YW0
Whirlpool FGP335YW1
Whirlpool FGP335YW2
Whirlpool FGP337GN0
Whirlpool FGP337GN1
Whirlpool FGP337GN5
Whirlpool FGP337GQ0
Whirlpool FGP337GQ1
Whirlpool FGP337GQ5
Whirlpool FGP337GW0
Whirlpool FGP337GW1
Whirlpool FGP337GW5
Whirlpool FGP337HN0
Whirlpool FGP337HQ0
Whirlpool FGP337HW0
Whirlpool FGP337KN0
Whirlpool FGP337KQ0
Whirlpool FGP337KW0
Whirlpool FGP337KW1 30" Gas Freestanding Standard Clean Range Electro
Whirlpool FGP345VL0
Whirlpool FGP345VL1
Whirlpool FGP345VL2
Whirlpool FGP345VW0
Whirlpool FGP345VW1
Whirlpool FGP345VW2
Whirlpool FGP345YL0
Whirlpool FGP345YW0
Whirlpool FGP355VL0
Whirlpool FGP355VL1
Whirlpool FGP355VL2
Whirlpool FGP355VL3
Whirlpool FGP355VW0
Whirlpool FGP355VW1
Whirlpool FGP355VW2
Whirlpool FGP355VW3
Whirlpool FGP355YL0
Whirlpool FGP355YW0
Whirlpool FGP357XL0
Whirlpool FGP357XW0
Whirlpool FGP357YL0
Whirlpool FGP357YL1
Whirlpool FGP357YL3
Whirlpool FGP357YW0
Whirlpool FGP357YW1
Whirlpool FGP357YW2
Whirlpool FGP357YW3
Frigidaire FGQ1442ES0 Frigidaire/dryer
Frigidaire FGQ332ES0 Frigidaire/gas Dryer
Frigidaire FGQB2152FE0 Frigidaire/dryer
Frigidaire FGQB4000FS0 Frigidaire/dryer
Frigidaire FGQBB30DS0 Frigidaire/dryer
Frigidaire FGR211AS0 Dryer - Frigidaire
Frigidaire FGR211AS1 Dryer - Frigidaire
Frigidaire FGR211AS2 Frigidaire/gas Dryer
Frigidaire FGR211AS3 Frigidaire/gas Dryer
Frigidaire FGR211AS4 Frigidaire/dryer
Frigidaire FGR211MAS0 Frigidaire/dryer
Frigidaire FGR221AS0 Dryer - Frigidaire
Frigidaire FGR231AS0 Dryer - Frigidaire
Frigidaire FGR231AS1 Dryer - Frigidaire
Frigidaire FGR231AS2 Frigidaire/dryer
Frigidaire FGR231AS3 Frigidaire/gas Dryer
Frigidaire FGR231AS4 Frigidaire/dryer
Frigidaire FGR231CAS4 Frigidaire/dryer
Frigidaire FGR311FS0 Frigidaire/dryer
Frigidaire FGR331AS0 Dryer - Frigidaire
Frigidaire FGR331AS1 Dryer - Frigidaire
Frigidaire FGR331KAS1 Frigidaire/gas Dryer
Frigidaire FGR341AC0 Frigidaire/dryer
Frigidaire FGR341AC1 Frigidaire/dryer
Frigidaire FGR341AS0 Dryer - Frigidaire
Frigidaire FGR341AS1 Dryer - Frigidaire
Frigidaire FGR641FS0 Frigidaire/dryer
Frigidaire FGR6600ES0 Frigidaire/dryer
Frigidaire FGR6600FS0 Frigidaire/dryer
Frigidaire FGRB5700DS0 Frigidaire/dryer
Frigidaire FGRB6600ES0 Frigidaire/dryer
Frigidaire FGRB6600FS0 Frigidaire/dryer
Frigidaire FGRB7800DS0 Frigidaire/dryer
Whirlpool FGS325RQ0 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ1 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD0 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD1 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD3 30" Gas Freestanding Self Clean Range
Whirlpool FGS335EN0
Whirlpool FGS335EQ0
Whirlpool FGS335EW0
Whirlpool FGS337GN0
Whirlpool FGS337GN1
Whirlpool FGS337GN5
Whirlpool FGS337GQ0
Whirlpool FGS337GQ1
Whirlpool FGS337GQ5
Whirlpool FGS337GQ6
Whirlpool FGS337GQ7
Whirlpool FGS337GW0
  #2 (permalink)
Old 06-14-2008, 08:14 AM
Junior Member
Default
Update for those interested. I found out the ignitor and safety valve work as needed. On this model the signal thru the ignitor to the safety valve is approx. 3.2 volts ac, the repair places won't help you with that much at all. Long story short, I did get a flame after turning the manual gas valve off, waiting about a minute and SLOWLY turning the gas back on. the pressure regulator works if the demand is slowly applied. So - does anybody have input on exactly how the regulator works. I understand the basics, but does it maybe have a high-flow stop or something that causes gas to not flow at all if the demand is sudden? such as a startup. I just want to be assured that if I replace it the oven will work.
  #3 (permalink)
Old 06-14-2008, 10:06 AM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
The glow bar, must draw about 3.2 amps in order for the saftey valve to open and alow gas to flow to the burner. East way to test, is put an amp probe on one of the glowbar wires and see what the current draw is
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #4 (permalink)
Old 06-16-2008, 07:58 AM
Junior Member
Default
Ok, we have 3.2 amp draw at the glow bar - the gas valve opens. I still get intermittent lighting, if I turn the manual gas valve off, and slowly turn it on - I get a light each time. Suggestions on how to get a for sure light off??
  #5 (permalink)
Old 06-16-2008, 09:38 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Marrel,
It should be a little bit over 3.2 amp to provide stable gas flow. If it's just 3.2 amps, that could be a problem.
__________________
  #6 (permalink)
Old 07-10-2008, 08:41 PM
Junior Member
Default New technical info.
OOps - let me back up, electricity 101. My volts to the safety valve are 3.2. The AMP draw on the wire to the ignitor, using a clamp on amprobe is 2.8. I can still get a light off if I turn the gas off and back on manually - however, after comparing the flame to another gas oven, this one is pretty puny. The comparison oven has a much 'longer' flame. So with that info., what do I change out? Thanks for you persistance.
  #7 (permalink)
Old 07-11-2008, 12:45 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by Marrel View Post
...OOps - let me back up, electricity 101. ...what do I change out?
Low voltage. This is a major problem. Try to plug it in a different outlet with proper power.
__________________
  #8 (permalink)
Old 07-11-2008, 03:10 PM
Junior Member
Default
I understood I was to have 3.2 or better AMP draw from the ignitor, I have 2.8 AMPS. The voltage I measured is after the ignitor at the safety valve.
  #9 (permalink)
Old 07-11-2008, 05:38 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sounds like the igniter is bad.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Double Wall Oven - Top Oven Not Working bigguy Oven Repair (including Ranges and Cooktops) 6 09-18-2008 10:03 AM
GE Wall Double Oven Top Oven Not Heating ryoung Oven Repair (including Ranges and Cooktops) 0 01-10-2008 09:02 PM
single wall oven tom blackburn Oven Repair (including Ranges and Cooktops) 0 12-20-2007 08:45 AM
Wall Oven Lee Oven Repair (including Ranges and Cooktops) 1 10-16-2007 12:25 PM
Wall Oven light goes off and on by itself josie Oven Repair (including Ranges and Cooktops) 2 10-16-2007 09:56 AM
