Discuss
Oven Outer Door Replacement
 in
Hi, We have an Amana art663ww. Our previous tenant broke the outer door to the oven (part number AP80260) so
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Outer Door Replacement
  #1 (permalink)
Old 09-04-2007, 06:58 AM
cnowen cnowen is offline
Junior Member
cnowen is on a distinguished road
Default Oven Outer Door Replacement
Model Number: art663ww   Brand: Amana   Age: 1 - 5 years
We have an Amana art663ww. Our previous tenant broke the outer door to the oven (part number AP80260) so we need to replace it. A repair guy quoted us $350 including parts and labor, which is ridiculous, considering we could buy a whold new stove for that much money. We'd like to try to do it ourselves, but before I go and order the part, I really need to know:
1. How difficult is this to do? Can any lay person do this or do you have to have special knowledge?
2. Are there any special tools involved. We'd need to factor those into the price.
3. How long (approximately) do you think this would take to do?
Any and all info is greatly appeciated!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-08-2007, 02:15 AM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
Here is the process:
Think where you would want to set the door on. Countertop works fine. Put a large thick beach towel on the countertop. Open the door at the first break point (about 30 degrees). Pull up on the door to remove it off its hinges. Set the door on the towel with the handle facing up. Then, using the door breakdown diagram replace the outer door glass.
Once finished, set the door back down on its hinges. Make sure the door is all the way down. Try to swing the door both ways a little bit. If feels fine, close it and try again.
That's about it. Should not take more than an hour.
Whatever you decide to do, I would not call that repair guy back for any other job. Even $250 sounds a bit much to replace this door glass.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven door won't come unlocked lfox Oven Repair (including Ranges and Cooktops) 0 08-09-2007 09:32 PM
whirlpool outer tub gmulvany2000 Washer Repair 2 08-06-2007 06:31 AM
loose oven door handle duck Oven Repair (including Ranges and Cooktops) 1 07-31-2007 07:04 PM
oven door locked jmiller Oven Repair (including Ranges and Cooktops) 2 07-20-2007 07:05 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
