I have a Frigidaire fef316asa electric range/oven and the elements in the oven will not heat. The bottom element has a black burn spot and appears to be burned out. When I turn on the broiler element it does not work either. When one goes, does the other not function or could it be something else. I was planning on replacing the element, but wanted to check first.
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman Thanks for the feedback. Yes, the stove top elements are working fine. I will try to replace the lower element and see if that heats up. If not, then I need to figure out plan B!
