Have a kitchenaid superba gas range oven mod#KGSC308LSS0. Does not heat up,just says low but doesn't get hot. Looked on here before and thought it would be control board cause i get no reading on voltmeter when oven is on. I got a new board but still no success. Now it seems like it must be the fuse but not sure which one. Any help would be much appreciated.
Originally Posted by: vilela65 Have a kitchenaid superba gas range oven mod#KGSC308LSS0. Does not heat up,just says low but doesn't get hot. Looked on here before and thought it would be control board cause i get no reading on voltmeter when oven is on. I got a new board but still no success. Now it seems like it must be the fuse but not sure which one. Any help would be much appreciated. Kill the power to the oven. Take the broiler draw out, and unplug the harness of the bake ignitor. Then get you volt meter and stick your leads of the meter in each one of the connectors, and then turn the power on, and ask for bake. You should read 120 volts there is the board you put in is good. If so replace the ignitor. I would also put the oven on broil, and see if the broil comes on. It would be odd, that both ignitors would be bad. Tom ApplianceEducator.com
