Discuss
KitchenAid cooktop won't spark
 in
Appliance - KiitchenAid cooktop, Model kgct305ewh0, approximately 10 years old. Issues - all four burners have stopped sparking. The knob
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » KitchenAid cooktop won't spark
  #1 (permalink)
Old 06-10-2008, 02:13 PM
Junior Member
nimsu71 is on a distinguished road
Default KitchenAid cooktop won't spark
Model Number: kgct305ewh0   Brand: Kitchen Aid   Age: More than 10 years
Issues - all four burners have stopped sparking. The knob still lets the gas out. So the cooktop can be use with the help of a match stick or lighter.
Based on primary research it seems like the following needs to be replace:
Spark module - Spark module for top burners. Instruction sheet included.
Part Number: AP3126624 made by WHIRLPOOL
However I want help for the following:
1. Is my assumption correct? Is it the spark module or something else?
2. Does this part from appliancepartspros.com come with installation instructions?
3. How can I get a wiring diagram for this cooktop? The web site say the following
Wiring diagram
Part Number: AP3077683 made by WHIRLPOOL
Requires special attention
Please give us a call at
1-877-477-7278
I really want to Do-It-Myself. However I want to do it right. Let me know if this is not a plug-n-play solution.
Thanks In advance
Nick
Ads By Google
Related Models
Whirlpool KGCT305EWH0
Whirlpool KGCT305GAL0
Whirlpool KGCT305GAL1
Whirlpool KGCT305GBL0
Whirlpool KGCT305GBL1
Whirlpool KGCT305GBL2
Whirlpool KGCT305GBT0
Whirlpool KGCT305GBT1
Whirlpool KGCT305GBT2
Whirlpool KGCT305GWH0
Whirlpool KGCT305GWH1
Whirlpool KGCT305GWH2
Whirlpool KGCT305TAL0
Whirlpool KGCT305TAL1
Whirlpool KGCT305TAL2
Whirlpool KGCT305TBL0
Whirlpool KGCT305TBL1
Whirlpool KGCT305TBL2
Whirlpool KGCT305TWH0
Whirlpool KGCT305TWH1
Whirlpool KGCT305TWH2
Whirlpool KGCT305XAL0
Whirlpool KGCT305XAL1
Whirlpool KGCT305XAL2
Whirlpool KGCT305XAL3
Whirlpool KGCT305XBL0
Whirlpool KGCT305XBL1
Whirlpool KGCT305XBL2
Whirlpool KGCT305XBL3
Whirlpool KGCT305XWH0
Whirlpool KGCT305XWH1
Whirlpool KGCT305XWH2
Whirlpool KGCT305XWH3
Whirlpool KGCT365AAL0
Whirlpool KGCT365AAL1
Whirlpool KGCT365AAL2
Whirlpool KGCT365ABL0
Whirlpool KGCT365ABL1
Whirlpool KGCT365ABL2
Whirlpool KGCT365AWH0
Whirlpool KGCT365AWH1
Whirlpool KGCT365AWH2
Whirlpool KGCT365BAL0
Whirlpool KGCT365BAL1
Whirlpool KGCT365BAL2
Whirlpool KGCT365BAL3
Whirlpool KGCT365BAL4
Whirlpool KGCT365BBL0
Whirlpool KGCT365BBL1
Whirlpool KGCT365BBL2
Whirlpool KGCT365BBL3
Whirlpool KGCT365BBL4
Whirlpool KGCT365BWH0
Whirlpool KGCT365BWH1
Whirlpool KGCT365BWH2
Whirlpool KGCT365BWH3
Whirlpool KGCT365BWH4
Whirlpool KGCT365EAL0
Whirlpool KGCT365EBL0
Whirlpool KGCT365EWH0
Whirlpool KGCT365GAL0
Whirlpool KGCT365GAL1
Whirlpool KGCT365GBL0
Whirlpool KGCT365GBL1
Whirlpool KGCT365GBL2
Whirlpool KGCT365GBT0
Whirlpool KGCT365GBT1
Whirlpool KGCT365GBT2
Whirlpool KGCT365GWH0
Whirlpool KGCT365GWH1
Whirlpool KGCT365GWH2
Whirlpool KGCT365TAL0
Whirlpool KGCT365TAL1
Whirlpool KGCT365TAL2
Whirlpool KGCT365TBL0
Whirlpool KGCT365TBL1
Whirlpool KGCT365TBL2
Whirlpool KGCT365TWH0
Whirlpool KGCT365TWH1
Whirlpool KGCT365TWH2
Whirlpool KGCT365XAL0
Whirlpool KGCT365XAL1
Whirlpool KGCT365XAL2
Whirlpool KGCT365XAL3
Whirlpool KGCT365XBL0
Whirlpool KGCT365XBL1
Whirlpool KGCT365XBL2
Whirlpool KGCT365XBL3
Whirlpool KGCT365XWH0
Whirlpool KGCT365XWH1
Whirlpool KGCT365XWH2
Whirlpool KGCT365XWH3
Whirlpool KGCT366EAL0
Whirlpool KGCT366EBL0
Whirlpool KGCT366EWH0
Whirlpool KGCT366GAL0
Whirlpool KGCT366GAL1
Whirlpool KGCT366GBL0
Whirlpool KGCT366GBL1
Whirlpool KGCT366GBL2
Whirlpool KGCT366GBT0
Whirlpool KGCT366GBT1
Whirlpool KGCT366GBT2
Whirlpool KGCT366GWH0
Whirlpool KGCT366GWH1
Whirlpool KGCT366GWH2
Whirlpool KGCV465MMT00 36" Pro - Line Cooktop
Whirlpool KGCV465MMT02 36" Pro - Line Cooktop
Whirlpool KGCV465MMT03 36" Pro - Line Cooktop
Whirlpool KGCV465MSS00 36" Pro - Line Cooktop
Whirlpool KGCV465MSS02 36" Pro - Line Cooktop
Whirlpool KGCV465MSS03 36" Pro - Line Cooktop
Whirlpool KGCV566MMT00 36" Gas Glass Surface Cooktop Pro - Line
Whirlpool KGCV566MMT01 36" Gas Glass Surface Cooktop Pro - Line
Whirlpool KGCV566MMT02 36" Gas Glass Surface Cooktop Pro - Line
Whirlpool KGCV566MSS00 36" Gas Glass Surface Cooktop Pro - Line
Whirlpool KGCV566MSS01 36" Gas Glass Surface Cooktop Pro - Line
Whirlpool KGCV566MSS02 36" Gas Glass Surface Cooktop Pro - Line
Whirlpool KGCV566RMT00 36" Gas Glass Ceran Cooktop
Whirlpool KGCV566RMT01 36" Gas Glass Ceran Cooktop
  #2 (permalink)
Old 06-11-2008, 07:14 AM
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default
Most Spark modules comes with 6 connections. 4 small connections (1for each burner) and 2 large connections for power input. The way it works is simple. Each burner knob is tied in with the rest. When you turn on a burner, power is sent to the spark module and it sparks all 4 burners at the same time. Pretty easy to replace. spark module maytag.jpg
  #3 (permalink)
Old 06-11-2008, 02:36 PM
Junior Member
rwalton is on a distinguished road
Default kitchenaid cooktop won't spark
I have a 10+ yr old cooktop kgct305x.
My problem is that it only sparks intermittently.
Usually when I plug and unplug it will work again for a while.
Have removed cover panel and tighteded all connections. Then it worked. Came back several hours later and no spark. Ghosts?
Do I need new ignighter module? Local shop recommends FSP Module-SPK RA bar code 4454392.
Looks like it will be a bear to install given limited space under counter.
This is my first time here. Should I be asking for help in another manner? Where do I look for response?
Richard walton.napa@gmail.com
  #4 (permalink)
Old 06-11-2008, 05:59 PM
Senior Expert
APP Volunteer
Default they ain't that expensive for a generic
You could check around and get a generic for less money. Yes they do get intermittant. Just start a new thread if you like and post yer model number. if I get a chance to look at your particular application I can give you a better explanation. Always striving to make it easier and cheaper on everyone will keep the costs down and help the whole US economy. Now if my dang overdue stimulation check will creep into mailbox here in the swamp.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cooktop - Get spark - no gas AndrewS Oven Repair (including Ranges and Cooktops) 2 01-30-2010 12:34 PM
need spark for Rosieres gas cooktop nccooker Oven Repair (including Ranges and Cooktops) 0 06-07-2009 11:32 AM
kitchenaid gas cooktop broken spark mod cbheck Oven Repair (including Ranges and Cooktops) 5 04-17-2009 03:40 PM
Kitchenaid cooktop spark intermittant Rich C Oven Repair (including Ranges and Cooktops) 1 12-24-2008 05:25 AM
no spark on cooktop slicker30 Oven Repair (including Ranges and Cooktops) 0 04-14-2008 11:09 PM
