Took off outside glass to clean. Broke side rails that hold the glass. ordered new side rails which also came with a new metal bottom piece. side rails have been redesigned to use plastic tabs at the bottom instead of screws. The side rails do not have enough clearence between them and the metal on the door, which has small clips that are srping loaded and space the door, to fit the around the door. The side rails have tabs that fit into holes as well so there is no play. I tried putting the glass on the TOP of the side rails as well but then the handle will not screw down and this is not how it is supposed to fit. Please help ASAP. Scott
