Discuss
oven problems
 in
Wife use self cleaning option yesterday - had to replace the thermostat fuse (Open circiut - found this to be
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven problems
  #1 (permalink)
Old 03-29-2010, 11:58 AM
Junior Member
billybobcfg is on a distinguished road
Default oven problems
Model Number: RBS275PDQ12   Brand: Whirlpool   Age: 5 - 10 years
Wife use self cleaning option yesterday - had to replace the thermostat fuse (Open circiut - found this to be normal after reading web posts, we will never self clean again). Installed new fuse and now getting F2-E1 error, code indicates keypad not connected so I inspected/cleaned ribbon cable but no help. Tech sheet with oven states to clear code press cancel - this does not work. It says to replace keypad, then possilbly the control board if the keypad doesn't fix it.
Bottom Line is it could be the keypad or the control panel (they are seperate on this unit). How do I know which one to replace. Their method is stupid and possibly double the cost if keypad is really OK.
Ads By Google
Related Models
Whirlpool RBS275PDQ12
Whirlpool RBS275PDQ13
Whirlpool RBS275PDQ14
Whirlpool RBS275PDQ16 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PDQ17 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PDQ2
Whirlpool RBS275PDQ4
Whirlpool RBS275PDQ6
Whirlpool RBS275PDQ8
Whirlpool RBS275PDS12
Whirlpool RBS275PDS14
Whirlpool RBS275PDS16 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PDS17 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PDT10
Whirlpool RBS275PDT11
Whirlpool RBS275PDT12
Whirlpool RBS275PDT13
Whirlpool RBS275PDT14
Whirlpool RBS275PDT16 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PDT17 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PRB00 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PRQ00 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PRS00 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PRT00 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS277PDB1
Whirlpool RBS277PDB2
Whirlpool RBS277PDB4
Whirlpool RBS277PDQ1
Whirlpool RBS277PDQ2
Whirlpool RBS277PDQ4
Whirlpool RBS305PDB1
Whirlpool RBS305PDB10
Whirlpool RBS305PDB11
Whirlpool RBS305PDB12
Whirlpool RBS305PDB13
Whirlpool RBS305PDB14
Whirlpool RBS305PDB16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDB17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDB2
Whirlpool RBS305PDB4
Whirlpool RBS305PDB6
Whirlpool RBS305PDB8
Whirlpool RBS305PDB9
Whirlpool RBS305PDQ1
Whirlpool RBS305PDQ10
Whirlpool RBS305PDQ11
Whirlpool RBS305PDQ12
Whirlpool RBS305PDQ13
Whirlpool RBS305PDQ14
Whirlpool RBS305PDQ16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDQ17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDQ2
Whirlpool RBS305PDQ4
Whirlpool RBS305PDQ6
Whirlpool RBS305PDQ8
Whirlpool RBS305PDQ9
Whirlpool RBS305PDS12
Whirlpool RBS305PDS14
Whirlpool RBS305PDS16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDS17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDT10
Whirlpool RBS305PDT11
Whirlpool RBS305PDT12
Whirlpool RBS305PDT13
Whirlpool RBS305PDT14
Whirlpool RBS305PDT16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDT17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDT8
Whirlpool RBS305PDT9
Whirlpool RBS305PDZ1
Whirlpool RBS305PDZ10
Whirlpool RBS305PDZ2
Whirlpool RBS305PDZ4
Whirlpool RBS305PDZ6
Whirlpool RBS305PDZ8
Whirlpool RBS305PDZ9
Whirlpool RBS305PRB00 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PRQ00 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PRS00 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PRT00 30" Built - in Electric Oven Self Clean
Whirlpool RBS307PDB1
Whirlpool RBS307PDB2
Whirlpool RBS307PDB4
Whirlpool RBS307PDQ1
Whirlpool RBS307PDQ2
Whirlpool RBS307PDQ4
Frigidaire RBSF117E1 BLACK Frg(v3) / Electric Cooktops and Control Box
Frigidaire RBSF117EL1 Frg(v2) / Electric Cooktops and Control Box
Frigidaire RBSF117EW1 Frg(v1) / Electric Cooktops and Control Box
Frigidaire RBSF129EL0 Frg(v4) / Electric Range
Frigidaire RBSF129EW0 Frg(v3) / Electric Range
Frigidaire RBUGCF95ED Frg(v6) / Wall Oven
Frigidaire RBUGCF95EK Frg(v7) / Wall Oven
Frigidaire RBUGCF95EW Frg(v5) / Wall Oven
Amana RC-10B Commercial Microwaves
Amana RC-10B-DD Commercial Microwaves
Amana RC-10B-PB Commercial Microwaves
Amana RC-10D Commercial Microwaves
Amana RC-10PB Commercial Microwaves
Amana RC-10S Commercial Microwaves
Amana RC-10SD Commercial Microwaves
Amana RC-10SE Commercial Microwaves
Amana RC-14 Commercial Microwaves
  #2 (permalink)
Old 03-30-2010, 01:44 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Would not hurt to clean the connector on the board, using electronic contact cleaner or isopropyl alcohol and a tooth brush. Check the tracks in the ribbon cable for hairline cracks, using a magnifying glass.
Make sure the connector is dry, reconnect everything and give it a try.
If it's still does not work, replace the control panel (key panel). Unfortunately there is no way how to test it instrumentally. Whirlpool did not provide any instructions for such test.
If you need the correct part number for the control panel, post the color.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL RBS275PDQ12 | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven problems jpreslee Oven Repair (including Ranges and Cooktops) 2 01-03-2010 06:52 AM
oven problems lauralmz Oven Repair (including Ranges and Cooktops) 0 08-27-2009 02:22 PM
Oven Problems mckay751 Oven Repair (including Ranges and Cooktops) 1 07-12-2009 10:51 PM
Oven problems Jbates Oven Repair (including Ranges and Cooktops) 0 02-16-2009 03:36 PM
oven problems racer951 Oven Repair (including Ranges and Cooktops) 1 01-07-2008 06:42 PM
