My whole range lost power and one of the causes can be a thermister. With an ohm meter the thermister reads open which should mean its bad. Should I not get a resistance reading. Just want to make sure before I order the part.
Originally Posted by: Fixit? My whole range lost power and one of the causes can be a thermister. With an ohm meter the thermister reads open which should mean its bad. Should I not get a resistance reading. Just want to make sure before I order the part. Checked around and it is the thermister!!!!
