The oven temperature would appear to reach the setting say 325. When we switched to convection bake the temp would be much lower say 245. Going back to bake the temp would agree with the convection bake. I replaced the control panel but the result was the same, so I replaced the temp sensor. I got a reading of 100 degrees and no heat. So I put the old sensor back in and the results are the same 100 and no heat. The heat elements meter at about 10 ohms.
