My front cook top left electrode will not spark.I switched the electrode with one that works and still had the same problem.I then opened the panel that has the spark module and switched the lead from one that works to the one that does not and still had the same problem.I was thinking the only other issue could possibly be the wire???Any input would be greatly appreciated. Conrad
