Discuss
GE Oven flashing Locked Door & won't heat
 in
Oven and glass top Electric, Spectra Profile. First trouble I've had - Digital readout/panel on top flashes LockedDoor and won't
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE Oven flashing Locked Door & won't heat
  #1 (permalink)
Old 03-26-2010, 12:20 PM
Junior Member
Doreen in FL is on a distinguished road
Default GE Oven flashing Locked Door & won't heat
Brand: GE   Age: 1 - 5 years
First trouble I've had - Digital readout/panel on top flashes LockedDoor and won't heat up. I had a turkey breast in the oven at 350 deg and came into kitchen half hour before timer was set to expire, to find that. The oven was no longer at 350 (began to do this maybe when someone looked inside or maybe hit the panel by mistake I thought) I tried off/clear, then turning on/off breaker to stove but nothing works to clear the message and make it actually Work again.
Stove top is working, and had to move the turkey breast to microwave... I hope this is not an expensive problem HELP!!
  #2 (permalink)
Old 03-26-2010, 12:33 PM
Junior Member
Default Found a 2007 post by Gene in reply to Heather !!
It worked! Thanks Heather, for having the issue then and Gene for replying with the fix that worked for me in 2010!
God Bless the Internet and forums like this!
  #3 (permalink)
Old 05-09-2011, 05:58 AM
Junior Member
Rose_Home6 is on a distinguished road
Default Gene - are you out there?
Gene - looks like you are an Appliance Superman. I am hoping that you or someone else can help. I have a 6-yr old GE Profile gas oven. I went to self-clean it but the door was not shut all the way. So I immediately turned off the cleaning, but the lock latch closed. So the display says "locked" and I cannot shut my stove door, or use it. But can't seem to reset the lock either. I have killed power to the unit for a few minutes, it reset the whole thing, but when it came back on - it said "locked" again. How to I out-smart this thing?
Thanks,
Tom
  #4 (permalink)
Old 08-01-2012, 04:01 PM
Junior Member
lnjstim is on a distinguished road
Default I am having the same problem with my GE double oven
I am having the same problem with my ge double oven. Please help!
  #5 (permalink)
Old 12-15-2015, 10:10 AM
Junior Member
Baltozmom is on a distinguished road
Default
I had this too and here is Genes response! It worked for me and sounds crazy but it works!!! I wanted to post this here in case anyone else has this problem. Mine happened when I had it open and sprayed cleaner in oven and I never turned on the self cleaning either... I called GE repair and was given a hard time by a lady and pushed to buy hinges and was told she was not going to help me take apart my oven when I just asked if the door pulls off.... Crazy! This was all it was Thanks Gene!!! :") I am going to keep this info next to my oven!
Push and hold the door light switch while restart the self clean. Keep holding the door switch, wait a minute then cancel the self clean and release the door switch after the "lock" is off.
Good luck and Happy New year.
Read more: Oven Door Latch Locked W/O Door
Appliance Repair Forum - Free Service from Appliance Parts Pros
  #6 (permalink)
Old 09-28-2016, 02:16 PM
Junior Member
dkienlen is on a distinguished road
Default question
the oven on top will not heat, the door opens but there is a continual massage-door locked-that keeps flashing
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven Door Latch Locked W/O Door hseeger Oven Repair (including Ranges and Cooktops) 8 01-28-2014 12:26 PM
OVen door locked, wont heat up after self cleaning pattisphotoframes@yahoo Oven Repair (including Ranges and Cooktops) 0 01-22-2010 06:36 PM
Oven Clock , Locked door display blinking but not locked RaviM Oven Repair (including Ranges and Cooktops) 2 08-05-2009 05:47 PM
Locked oven door wgrigson@cfl.rr.com Oven Repair (including Ranges and Cooktops) 0 11-21-2008 10:48 AM
oven thinks its locked flashing codes emsdoc Oven Repair (including Ranges and Cooktops) 1 12-25-2007 01:23 PM
