Discuss
stove top ignitors failing
 in
yesterday two of the four burners of the stove top worked only some of the time. Today those two will
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » stove top ignitors failing
  #1 (permalink)
Old 06-04-2008, 07:05 AM
Junior Member
jrmonson is on a distinguished road
Default stove top ignitors failing
Model Number: arg7600ww   Brand: Amana   Age: More than 10 years
yesterday two of the four burners of the stove top worked only some of the time. Today those two will not ignite at all. The snapping sound happens whenever I turn any of the four burners on. I took the heavy caps off the burners, and there is spark to ignite the right front and left rear burners only. Could a wire be loose or should I look for a part to be replaced?
And, how do you remove the stove top for access?
Thank you.
Ads By Google
Related Models
Amana ARG7600WW RANGE- S/C S/I DDRAFT GAS
Amana ARG7600WW RANGE- S/C F/S GAS
Amana ARG7800CC RANGE- S/C S/I DDRAFT GAS
Amana ARG7800E RANGE- S/C S/I DDRAFT GAS
Amana ARG7800LL RANGE- S/C S/I DDRAFT GAS
Amana ARG7800SS RANGE- S/C S/I DDRAFT GAS
Amana ARG7800WW RANGE- S/C S/I DDRAFT GAS
Amana ARGS7650CC RANGE- S/C S/I GAS
Amana ARGS7650E RANGE- S/C S/I GAS
Amana ARGS7650LL RANGE- S/C S/I GAS
Amana ARGS7650SS RANGE- S/C S/I GAS
Amana ARGS7650WW RANGE- S/C S/I GAS
Amana ARH660 RANGE- S/C S/I DDRAFT GAS
Amana ARH660 RANGE- S/C S/I DDRAFT ELE
Amana ARH660HR RANGE- S/C S/I DDRAFT ELE
Amana ARH664E RANGE- S/C S/I DDRAFT ELE
Amana ARH664WW RANGE- S/C S/I DDRAFT ELE
Amana ARH665E RANGE- S/C S/I DDRAFT ELE
Amana ARH665WW RANGE- S/C S/I DDRAFT ELE
Amana ARH667E RANGE- S/C F/S ELE
Amana ARH667WW RANGE- S/C S/I DDRAFT ELE
Amana ARH6700E RANGE- S/C S/I DDRAFT GAS
Amana ARH6700E RANGE- S/C F/S ELE
Amana ARH6700LL RANGE- S/C S/I DDRAFT GAS
Amana ARH6700LL RANGE- S/C F/S ELE
Amana ARH6700WW RANGE- S/C S/I DDRAFT GAS
Amana ARH6710E RANGE- S/C S/I DDRAFT GAS
Amana ARH6710LL RANGE- S/C S/I DDRAFT GAS
Amana ARH6710WW RANGE- S/C S/I DDRAFT GAS
Amana ARHC7700E RANGE- S/C S/I DDRAFT ELE
Amana ARHC7700LL RANGE- S/C S/I DDRAFT ELE
Amana ARHC7700WW RANGE- S/C S/I DDRAFT ELE
Amana ARHC8700E RANGE- S/C F/S ELE
Amana ARHC8700LL RANGE- S/C F/S ELE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
which part is failing? clwheeler Washer Repair 1 02-19-2010 02:43 PM
Stovetop ignitors all failing Netsearcher Oven Repair (including Ranges and Cooktops) 0 01-27-2010 07:19 AM
GE Profie stove ignitors not working kaddu Oven Repair (including Ranges and Cooktops) 0 12-16-2009 02:01 PM
Gas Ignitors loose on Thermador stove top lsb1264 Oven Repair (including Ranges and Cooktops) 0 11-04-2008 09:20 AM
Stove-top ignitors not working jood Oven Repair (including Ranges and Cooktops) 1 09-12-2008 05:59 PM
