Discuss
oven "moaning" sound then faint "poof" sound; later, large "poof" popped door open
 in
Hello, Our GE Profile XL44 oven is around 4-5 years old. I've recently noticed that when using the baking functionality
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven "moaning" sound then faint "poof" sound; later, large "poof" popped door open
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 03-23-2010, 10:43 AM
Junior Member
samej71 is on a distinguished road
Default oven "moaning" sound then faint "poof" sound; later, large "poof" popped door open
Model Number: GE Profile XL44 (JGB910WEC4WW)   Brand: GE   Age: 1 - 5 years
Hello,
I've recently noticed that when using the baking functionality of the oven that when the oven cycles (not sure if it is when it cycles on or cycles off) it will give a faint "moaning" (slightly decreasing in pitch) sound, followed by a very brief silence, and then a small "poof" sound.
I started the oven last night to preheat it and a turned on a burner to heat a pot of water on the stove. As I walked over to check on the water in the pot, there was a small explosion (a large poof) in the oven that popped the oven door open slightly and cleared what looks like most of the dust bunnies out from under the stove. I immediately turned off the oven and saw the flames on the stove burner were mostly yellow and not blue. We turned off the burner and assessed the situation as best we could. After making sure we did not have a gas leak of some kind, I turned the stove burner back on. Within about 30-45 seconds the flames were mostly back to blue.
I don't know if the moaning noise I mentioned earlier is related to the pop in the oven, or if, because the stove flames were yellow, there may have simply been something in the gas line that caused this issue.
All stove burners work great, and so does the broiler. Under a careful and watchful eye, I turned the oven on to "bake" and saw the ignitor's yellow glow through the vents on the floor of the oven. I initially read it can take 30-60 seconds for the oven to come on, so I gave it a little more than a minute but the gas did not come on. I didn't hear the gas flow, smell gas, or see the glow/feel the heat. I turned it off.
From reading the posts in the forum, it seems most likely that the bottom ignitor is my problem--but nobody else has mentioned (that I saw) any "moaning" sound, so I don't know if I have two concurrent problems or if this sound is just another symptom of a ignitor going (gone?) bad.
Any quick assistance anyone can provide is appreciated. If the votes are cast that it is only the ignitor, then I'll pick it up at a local supply store on the way home and swap out the part. But if it sounds like it might be a variety of parts or a number of possible causes, then I'll probably just call a professional to diagnose the problems (and pay out the nose, I'm sure).
Thanks!
--James
Related Models
Bosch GE010-010
Bosch GE010-020
Frigidaire GEA1310A19
Frigidaire GEA1314A19
Whirlpool GEC9858EQ0 DRYER
Whirlpool GEC9858EQ1 ELECTRIC DRYER
Whirlpool GEC9858EZ0 DRYER
Whirlpool GEC9858EZ1 ELECTRIC DRYER
Whirlpool GEC9858HQ0 ELECTRIC DRYER
Whirlpool GEC9858HQ1 ELECTRIC DRYER
Whirlpool GEC9858HZ0 ELECTRIC DRYER
Whirlpool GEC9858HZ1 ELECTRIC DRYER
Frigidaire GED15P1 Gib(v1) / Dehumidifier
Frigidaire GED25P1 Gib(v1) / Dehumidifier
Frigidaire GED30P1 Gib(v2) / Dehumidifier
Frigidaire GED40P2 Gib(v3) / Dehumidifier
Frigidaire GED50P1 Gib(v4) / Dehumidifier
Frigidaire GEF300PADA Gib(v1) / Electric Range
Frigidaire GEF300PAWA Gib(v2) / Electric Range
Gibson GEF3015KWA ELECTRIC RANGE
Gibson GEF3015KWC ELECTRIC RANGE
Frigidaire GEF301SADA Gib(v2) / Electric Range
Frigidaire GEF301SAWA Gib(v1) / Electric Range
Gibson GEF305PJSA Gibson/electric Range
Gibson GEF305PJSB Gibson/electric Range
Frigidaire GEF311WADA Gib(v2) / Electric Range
Frigidaire GEF311WAWA Gib(v1) / Electric Range
Frigidaire GEF312BADA Gib(v1) / Electric Range
Frigidaire GEF312BAWA Gib(v2) / Electric Range
Frigidaire GEF322BBDA Gib(v1) / Electric Range
Frigidaire GEF322BBDB Gib(v1) / Electric Range
Frigidaire GEF322BBDC Gib(v1) / Electric Range
Frigidaire GEF322BBWA Gib(v2) / Electric Range
Frigidaire GEF322BBWB Gib(v2) / Electric Range
Frigidaire GEF322BBWC Gib(v2) / Electric Range
Frigidaire GEF322WBDA Gib(v3) / Electric Range
Frigidaire GEF322WBDB Gib(v3) / Electric Range
Frigidaire GEF322WBDC Gib(v4) / Electric Range
Frigidaire GEF322WBDD Gib(v3) / Electric Range
Frigidaire GEF322WBWA Gib(v4) / Electric Range
Frigidaire GEF322WBWB Gib(v5) / Electric Range
Frigidaire GEF322WBWC Gib(v6) / Electric Range
Frigidaire GEF322WBWD Gib(v4) / Electric Range
Frigidaire GEF324BFDA Gib(v1) / Electric Range
Frigidaire GEF324BFWA Gib(v2) / Electric Range
Gibson GEF331AS0 Dryer - Gibson
Gibson GEF331AS1 Dryer - Gibson
Gibson GEF331AS2 Gibson/electric Dryer
Gibson GEF331CS0 Gibson/dryer
Frigidaire GEF350SBDA Gib(v1) / Electric Range
Frigidaire GEF350SBDB Gib(v1) / Electric Range
Frigidaire GEF350SBDC Gib(v1) / Electric Range
Frigidaire GEF350SBWA Gib(v2) / Electric Range
Frigidaire GEF350SBWB Gib(v2) / Electric Range
Frigidaire GEF350SBWC Gib(v2) / Electric Range
Gibson GEF351FSA Gibson/electric Range
Gibson GEF351FSB ELECTRIC RANGE
Gibson GEF352BHDB Gibson/electric Range
Gibson GEF352BHWB Gibson/electric Range
Gibson GEF352CHSB Gibson/electric Range
Frigidaire GEF354BADA Frg(v1) / Electric Range
Frigidaire GEF354BAWA Frg(v2) / Electric Range
Frigidaire GEF354BBDA Gib(v1) / Electric Range
Frigidaire GEF354BBDB Gib(v1) / Electric Range
Frigidaire GEF354BBDC Gib(v1) / Electric Range
Frigidaire GEF354BBWA Gib(v2) / Electric Range
Frigidaire GEF354BBWB Gib(v2) / Electric Range
Frigidaire GEF354BBWC Gib(v2) / Electric Range
Frigidaire GEF355BFDA Gib(v1) / Electric Range
Frigidaire GEF355BFWA Gib(v2) / Electric Range
Frigidaire GEF355CFSA Gib(v0) / Electric Range
Frigidaire GEF357BABA Gib(v1) / Electric Range
Frigidaire GEF357BABB Gib(v2) / Electric Range
Frigidaire GEF357CBSA Gib(v1) / Electric Range
Frigidaire GEF357CBSB Gib(v0) / Electric Range
Frigidaire GEF357CBSC Gib(v1) / Electric Range
Frigidaire GEF357CBSD Gib(v2) / Electric Range
Frigidaire GEF357CBTA Gib(v2) / Electric Range
Frigidaire GEF357CBTB Gib(v0) / Electric Range
Frigidaire GEF357CBTC Gib(v3) / Electric Range
Frigidaire GEF357CBTD Gib(v4) / Electric Range
Frigidaire GEF365BHDA ELECTRIC RANGE
Frigidaire GEF365BHSA ELECTRIC RANGE
Frigidaire GEF365BHWA ELECTRIC RANGE
Frigidaire GEF400WAW1 Gib(v2) / Electric Range
Frigidaire GEF400WAWA Gib(v1) / Electric Range
 GELP Air Conditioner
Whirlpool GEN2000HQ0 ELECTRIC DRYER
Whirlpool GEN2000HQ1 ELECTRIC DRYER
Whirlpool GEN2000HZ0 ELECTRIC DRYER
Whirlpool GEN2000HZ1 ELECTRIC DRYER
Whirlpool GEQ8811KQ0 DRYER
Whirlpool GEQ8811KT0 DRYER
Whirlpool GEQ8811LG0 DRYER
Whirlpool GEQ8811LG1 27"ELECTRIC DRYER
Whirlpool GEQ8811LL0 DRYER
Whirlpool GEQ8811LL1 27"ELECTRIC DRYER
Whirlpool GEQ8811LW0 DRYER
Whirlpool GEQ8811LW1 27"ELECTRIC DRYER
Whirlpool GEQ8811PG0 27"ELECTRIC DRYER
Whirlpool GEQ8811PG1 27"ELECTRIC DRYER
Whirlpool GEQ8811PL0 27"ELECTRIC DRYER
Whirlpool GEQ8811PL1 27"ELECTRIC DRYER
Whirlpool GEQ8811PW0 27"ELECTRIC DRYER
Whirlpool GEQ8811PW1 27"ELECTRIC DRYER
Whirlpool GEQ8821KQ0 DRYER
Whirlpool GEQ8821KT0 DRYER
Whirlpool GEQ8821LL0 DRYER
Whirlpool GEQ8821LL1 27"ELECTRIC DRYER
Whirlpool GEQ8821LW0 DRYER
Whirlpool GEQ8821LW1 27"ELECTRIC DRYER
Whirlpool GEQ8831LL0 27"ELECTRIC DRYER
Whirlpool GEQ8831LW0 27"ELECTRIC DRYER
Whirlpool GEQ8858EQ0 ELECTRIC DRYER
Whirlpool GEQ8858EZ0 ELECTRIC DRYER
Whirlpool GEQ8858HQ0 DRYER
Whirlpool GEQ8858HQ1 ELECTRIC DRYER
Whirlpool GEQ8858HZ0 DRYER
Whirlpool GEQ8858HZ1 ELECTRIC DRYER
Whirlpool GEQ8858JQ0 ELECTRIC DRYER
  #2 (permalink)
Old 03-23-2010, 12:03 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
My vote goes toward a failing (or failed, now) igniter. I have heard "moaning" sounds from heating elements (of which is your igniter). However, I can conceive of the gas valve emitting that noise, if the igniter begins to fail. Your unit has two: one for Bake, and one for Broil. You'll need to test to see which one is the culprit.
  #3 (permalink)
Old 03-24-2010, 07:05 AM
Junior Member
Default
Thank you for replying.
I bought an ignitor on the way home and replaced the lower one since the broiler was working fine.
After running a series of tests, it seems like it is safely working again and also took care of the whine and poof sound.
Thanks again!
--James
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kitchenaide icemaker making "laboring" sound enofsinger Refrigerator & Freezer Repair 0 10-24-2009 08:07 AM
Works on "rinse only" but stops on "wash". Bill E Dishwasher Repair 5 05-27-2009 03:00 AM
Gallery Series ""Water Wont Go In"" juancruz Washer Repair 1 04-28-2009 06:06 PM
"Oven" and "Heating" LEDs blinking dwartz Oven Repair (including Ranges and Cooktops) 1 06-23-2008 10:21 PM
Agitator makes loud "smashing sound" during spin cycle Spug Washer Repair 3 04-06-2008 05:43 PM
