After using the oven for 3 days straight I started the self-cleaning cycle, then decided to cancel it...that was the last time the oven could be used, since then nothing works on the oven, when you press on the control to use oven it does not even click, it does nothing. I would appreciate any help. Thanks; granny504
A model number may help others help you
Many units have an over temperature thermostat that may have blown. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: granny504 After using the oven for 3 days straight I started the self-cleaning cycle, then decided to cancel it...that was the last time the oven could be used, since then nothing works on the oven, when you press on the control to use oven it does not even click, it does nothing. I would appreciate any help. Thanks; granny504 If you pulled out the oven, and take the back panel off there will be a thermostat back there, that could be the problem. The thermostat is about the size of a quarter, and has 2 wires coming to it, and is held in by 2 screws. With the powerr off, I want you to take the 2 wires off the thermostat, and put the terminal ends together, and then put some tape around them to hold them together, and to be sure the terminal ends do not hit metal, and then turn the power on to the oven and see if it works. If it does do not run the oven with the part jumped out. The reason it went out is because the temperature in the oven in the clean cycle got to hot. So inside the oven is a thin rod. It is mounted up high on the back wall. It is called the sensor. Replace it too, and you will have it. Tom ApplianceEducator.com - Parts
