Discuss
GE Oven - Broiler does not work
 in
Model number is JBP30A2WW. As the Topic title says the broiler is not working. This went on for several months
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE Oven - Broiler does not work
  #1 (permalink)
Old 09-01-2007, 09:03 AM
martincregg martincregg is offline
Junior Member
martincregg is on a distinguished road
Default GE Oven - Broiler does not work
Brand: -brand-   Age: 5 - 10 years
As the Topic title says the broiler is not working. This went on for several months then suddenly the broiler came on when we switched on the oven. This eventually produced an error code - sorry forgot what that was.
I tried disconnecting the two wires to the broiler element but this also stopped the oven from working. I left it that way for 3 weeks and have just used the surface rings.
I have just reconnected the two wires to the broiler. It does not work but the oven does.
When I turn the dial to the broiler setting, I check the power and there does not seem to be any at the terminals that go to the broiler. (sorry about that bad English grammar!)
I was hoping to get the error code so I could report that here.
Not sure if this is enough / accurate info required for someone to help me but appreciate any tips...
The unit is around 10 years old.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-01-2007, 11:46 AM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
Well, if when the broil cycle is on the broil element gets no power, that probably means that the broil relay on the control board is bad. Could you double check your model number? JBP30A2WW does not come up. Check the last few digits.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool oven does not work bob zaveri Oven Repair (including Ranges and Cooktops) 1 08-30-2007 08:43 PM
Oven Does Not Work JEANNIE Oven Repair (including Ranges and Cooktops) 6 08-29-2007 03:07 PM
Oven does not work... Ruben Oven Repair (including Ranges and Cooktops) 1 08-17-2007 09:02 AM
oven won't work cherylknudsen Oven Repair (including Ranges and Cooktops) 1 08-11-2007 05:43 PM
oven/broiler control unit dynaguy Oven Repair (including Ranges and Cooktops) 1 07-31-2007 05:36 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
