Discuss
gas range-electronics-error display
 in
Tappan was 'dinging'(audio) almost non-stop without any apparent reason. No error codes visible. After turning off the electric to it
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » gas range-electronics-error display
  #1 (permalink)
Old 09-01-2007, 07:48 AM
Junior Member
deaconjmpc is on a distinguished road
Default gas range-electronics-error display
Model Number: 30-3989   Brand: Tappan   Age: More than 10 years
Tappan was 'dinging'(audio) almost non-stop without any apparent reason. No error codes visible. After turning off the electric to it from central panel box and turning back on, the 'dinging' stopped.
Now none of the control buttons are functional. Whenever a button is pushed(clock, bake temp, etc.) the word 'OFF' appears in the read out panel.
Any suggestions?
Ads By Google
Related Models
Frigidaire 30-3989-00-01 Tap(v1) / Gas Range
Frigidaire 30-3989-00-02 Tap(v3) / Gas Range
Frigidaire 30-3989-00-03 Tap(v1) / Gas Range
Frigidaire 30-3989-00-04 Tap(v3) / Gas Range
Frigidaire 30-3989-00-05 Tap(v5) / Gas Range
Frigidaire 30-3989-00-06 Tap(v1) / Gas Range
Frigidaire 30-3989-00-07 Tap(v1) / Gas Range
Frigidaire 30-3989-23-01 Tap(v2) / Gas Range
Frigidaire 30-3989-23-02 Tap(v4) / Gas Range
Frigidaire 30-3989-23-03 Tap(v2) / Gas Range
Frigidaire 30-3989-23-04 Tap(v4) / Gas Range
Frigidaire 30-3989-23-05 Tap(v6) / Gas Range
Frigidaire 30-3989-23-06 Tap(v2) / Gas Range
Frigidaire 30-3989-23-07 Tap(v2) / Gas Range
Frigidaire 30-3991-00-01 Tap(v1) / Gas Range
Frigidaire 30-3991-00-02 Tap(v1) / Gas Range
Frigidaire 30-3991-00-03 Tap(v1) / Gas Range
Frigidaire 30-3991-23-01 Tap(v2) / Gas Range
Frigidaire 30-3991-23-02 Tap(v2) / Gas Range
Frigidaire 30-3991-23-03 Tap(v2) / Gas Range
Frigidaire 30-4082-00-01 Tap(v1) / Gas Range
Frigidaire 30-4082-00-02 Tap(v2) / Gas Range
Frigidaire 30-4182-23-01 Tap(v3) / Gas Range
Frigidaire 30-4182-23-02 Tap(v4) / Gas Range
Frigidaire 30-4282-00-01 Tap(v1) / Gas Range
Frigidaire 30-4282-00-02 Tap(v1) / Gas Range
Frigidaire 30-4282-00-03 Tap(v1) / Gas Range
Frigidaire 30-4282-00-04 Tap(v0) / Gas Range
Frigidaire 30-4382-23-01 Tap(v1) / Gas Range
Frigidaire 30-4382-23-02 Tap(v2) / Gas Range
Frigidaire 30-4382-23-03 Tap(v3) / Gas Range
Frigidaire 30-4382-23-04 Tap(v4) / Gas Range
Frigidaire 30-4382-23-05 Tap(v0) / Gas Range
Frigidaire 30-4387-00-01 Tap(v1) / Range
Frigidaire 30-4387-00-02 Tap(v5) / Range
Frigidaire 30-4387-00-03 Tap(v9) / Range
Frigidaire 30-4387-18-01 Tap(v4) / Range
Frigidaire 30-4387-18-02 Tap(v8) / Range
Frigidaire 30-4387-18-03 Tap(v12) / Range
Frigidaire 30-4387-23-01 Tap(v2) / Range
Frigidaire 30-4387-23-02 Tap(v6) / Range
Frigidaire 30-4387-23-03 Tap(v10) / Range
Frigidaire 30-4387-66-01 Tap(v3) / Range
Frigidaire 30-4387-66-02 Tap(v7) / Range
Frigidaire 30-4387-66-03 Tap(v11) / Range
Frigidaire 30-4388-00-01 Tap(v1) / Gas Range
Frigidaire 30-4388-00-02 Tap(v5) / Gas Range
Frigidaire 30-4388-00-03 Tap(v9) / Gas Range
Frigidaire 30-4388-00-04 Tap(v13) / Gas Range
Frigidaire 30-4388-08-01 Tap(v4) / Gas Range
Frigidaire 30-4388-08-02 Tap(v8) / Gas Range
Frigidaire 30-4388-08-03 Tap(v12) / Gas Range
Frigidaire 30-4388-08-04 Tap(v16) / Gas Range
Frigidaire 30-4388-23-01 Tap(v2) / Gas Range
Frigidaire 30-4388-23-02 Tap(v6) / Gas Range
Frigidaire 30-4388-23-03 Tap(v10) / Gas Range
Frigidaire 30-4388-23-04 Tap(v14) / Gas Range
Frigidaire 30-4388-66-01 Tap(v3) / Gas Range
Frigidaire 30-4388-66-02 Tap(v7) / Gas Range
Frigidaire 30-4388-66-03 Tap(v11) / Gas Range
Frigidaire 30-4388-66-04 Tap(v15) / Gas Range
Frigidaire 30-4687-00-01 Tap(v1) / Gas Range
Frigidaire 30-4687-00-02 Tap(v5) / Gas Range
Frigidaire 30-4687-00-03 Tap(v9) / Gas Range
Frigidaire 30-4687-08-01 Tap(v4) / Gas Range
Frigidaire 30-4687-08-02 Tap(v8) / Gas Range
Frigidaire 30-4687-08-03 Tap(v12) / Gas Range
Frigidaire 30-4687-23-01 Tap(v2) / Gas Range
Frigidaire 30-4687-23-02 Tap(v6) / Gas Range
Frigidaire 30-4687-23-03 Tap(v10) / Gas Range
Frigidaire 30-4687-66-01 Tap(v3) / Gas Range
Frigidaire 30-4687-66-02 Tap(v7) / Gas Range
Frigidaire 30-4687-66-03 Tap(v11) / Gas Range
Frigidaire 30-4688-00-01 Tap(v1) / Gas Range
Frigidaire 30-4688-00-02 Tap(v5) / Gas Range
Frigidaire 30-4688-00-03 Tap(v9) / Gas Range
Frigidaire 30-4688-00-04 Tap(v13) / Gas Range
Frigidaire 30-4688-08-01 Tap(v4) / Gas Range
Frigidaire 30-4688-08-02 Tap(v8) / Gas Range
Frigidaire 30-4688-08-03 Tap(v12) / Gas Range
Frigidaire 30-4688-08-04 Tap(v16) / Gas Range
Frigidaire 30-4688-23-01 Tap(v2) / Gas Range
Frigidaire 30-4688-23-02 Tap(v6) / Gas Range
Frigidaire 30-4688-23-03 Tap(v10) / Gas Range
Frigidaire 30-4688-23-04 Tap(v14) / Gas Range
Frigidaire 30-4688-66-01 Tap(v3) / Gas Range
Frigidaire 30-4688-66-02 Tap(v7) / Gas Range
Frigidaire 30-4688-66-03 Tap(v11) / Gas Range
Frigidaire 30-4688-66-04 Tap(v15) / Gas Range
Frigidaire 30-4932-00-01 Tap(v1) / Gas Range
Frigidaire 30-4932-23-01 Tap(v2) / Gas Range
Frigidaire 30-4942-00-01 Tap(v1) / Gas Range
Frigidaire 30-4942-00-02 Tap(v3) / Gas Range
Frigidaire 30-4942-00-03 Tap(v3) / Gas Range
Frigidaire 30-4942-00-04 Tap(v1) / Gas Range
Frigidaire 30-4942-00-06 Tap(v1) / Gas Range
Frigidaire 30-4942-00-07 Tap(v1) / Gas Range
Frigidaire 30-4942-23-01 Tap(v2) / Gas Range
Frigidaire 30-4942-23-02 Tap(v4) / Gas Range
Frigidaire 30-4942-23-03 Tap(v4) / Gas Range
Frigidaire 30-4942-23-04 Tap(v2) / Gas Range
Frigidaire 30-4942-23-05 Tap(v3) / Gas Range
Frigidaire 30-4942-23-06 Tap(v2) / Gas Range
Frigidaire 30-4942-23-07 Tap(v2) / Gas Range
Frigidaire 30-4952-00-01 Tap(v1) / Gas Range
Frigidaire 30-4952-00-02 Tap(v2) / Gas Range
Frigidaire 30-4952-00-03 Tap(v3) / Gas Range
Frigidaire 30-4952-00-04 Tap(v2) / Gas Range
Frigidaire 30-4952-00-05 Tap(v0) / Gas Range
Frigidaire 30-4962-00-01 Tap(v1) / Gas Range
Frigidaire 30-4962-23-01 Tap(v2) / Gas Range
Frigidaire 30-4972-00-01 Tap(v1) / Gas Range
Frigidaire 30-4972-23-01 Tap(v2) / Gas Range
Frigidaire 30-4979-00-01 Tap(v1) / Gas Range
Frigidaire 30-4979-00-02 Tap(v4) / Gas Range
Frigidaire 30-4979-00-03 Tap(v1) / Gas Range
Frigidaire 30-4979-00-04 Tap(v1) / Gas Range
Frigidaire 30-4979-08-01 Tap(v3) / Gas Range
Frigidaire 30-4979-08-02 Tap(v6) / Gas Range
Frigidaire 30-4979-23-01 Tap(v2) / Gas Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
PF error on Whirlpool Gas Range display jld1969 Oven Repair (including Ranges and Cooktops) 3 04-11-2011 05:15 PM
Error Sd or 5D in display - what does it mean whirlpoollady10 Washer Repair 1 02-11-2010 06:43 PM
F1 error and very dim display mikefoos Oven Repair (including Ranges and Cooktops) 1 08-21-2009 02:00 PM
Electronics Error Code Richard G Oven Repair (including Ranges and Cooktops) 4 03-26-2009 05:05 PM
F-1 E2 Error on Display ceallachqn Oven Repair (including Ranges and Cooktops) 0 05-16-2008 11:02 AM
