Discuss
Clock/timer
 in
Built in gas oven. I installed the oven at our farm. We don't live there but 1 or 2
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Clock/timer
  #1 (permalink)
Old 06-01-2008, 03:44 PM
olefin32 olefin32 is offline
Junior Member
olefin32 is on a distinguished road
Default Clock/timer
Model Number: FGB24L2ABA   Brand: Frigidaire   Age: 1 - 5 years
Built in gas oven. I installed the oven at our farm. We don't live there but 1 or 2 days a month and doubt the oven has been turned on a dozen times and then only to warm something.
Clock/timer works as usual but fails to start igniter.
I have the schematic, VOM and tired the below items.
1. Unplugged igniter, checked continuity... OK.
2. Set control to heat and set temperature. With igniter unplugged showed no voltage at BR-1 pin or the other pin W-1.
3. Removed wiring connector from control panel (clock/timer). From wiring end, V-1 and V-1, checked continuity through temperature probe... OK.
4. From wiring end of connector checked continuity from wire BR-1 to neutral pin... OK.
Looks like a faulty expensive control panel to me but strange why the clock and timer works OK?
First time for me to trouble shoot a gas oven but I see the igniter is in series with the gas valve. So how does this normally function? My guess, after the igniter heats, the resistance drops and allows current to open the gas valve?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-01-2008, 05:30 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Looks like the problem is a bad K3 relay on the control board which should provide 120VAC to the igniter. This relay does not affect other functions of the control board.
If you are able to find such relay (by matching numbers on it), you can try to replace it. Otherwise the control board has to be replaced.
- The part number for the control board is AP2129233
Here are the break down diagrams for the Frigidaire oven Model FGB24L2ABA
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 06-01-2008, 06:36 PM
Junior Member
Default
I had suspected the relay, since I couldn't hear it click. I'll try to find a replacement before replacing the complete board.
Gene, thanks for the suggestion and the quick comeback.
  #4 (permalink)
Old 06-01-2008, 08:32 PM
Junior Member
Default
I checked the relay coil and it has continuity. Now I'm thinking the relay is probably OK. I have the control board with me but that is about all I can check. When I go back to the farm in a few weeks I'll hook it up and check to see if the coil is getting 12 volts from the timer. If there is no low voltage getting to the coil, the timer is the culprit and I'll have to replace the board.
  #5 (permalink)
Old 06-19-2008, 07:36 PM
Junior Member
Default
I was back at the farm. Checked to see if the relay coil was getting voltage from the timer when timer was calling for heat..... I found no voltage at relay coil. That confirms a bad timer.
Also to check everything else.... temporary bypassed the relay contacts... the igniter came on and the burner lit.
Now I will be ordering a new timer/clock.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Gas oven Clock/timer Replacement ChuckH Oven Repair (including Ranges and Cooktops) 8 11-17-2008 08:31 AM
clock/timer bizzare behavior, no fault code workpot Oven Repair (including Ranges and Cooktops) 1 04-25-2008 04:17 PM
no error codes; is Clock/Timer EOC the problem? 2132mg Oven Repair (including Ranges and Cooktops) 1 02-12-2008 12:51 PM
Does GE JKP54GOV have seperate clock and timer unit bethgsimm Oven Repair (including Ranges and Cooktops) 3 01-20-2008 11:31 AM
Oven clock, timer, display is blank. dorannj Oven Repair (including Ranges and Cooktops) 0 09-12-2007 09:17 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
