Discuss
bake element will not heat up
 in
The lower bake element burned through causing arcing. I installed a new element but it will not heat up. I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » bake element will not heat up
  #1 (permalink)
Old 03-20-2010, 09:28 AM
Junior Member
aljoe is on a distinguished road
Question bake element will not heat up
Model Number: AER5715QAQ   Brand: Amana   Age: 1 - 5 years
The lower bake element burned through causing arcing. I installed a new element but it will not heat up. I checked the voltage, I have 120 volts on the red wire and no voltage on the other yellow wire coming from the control panel. Shouldn't there be 120 volts coming to each end of the element when it is the bake cycle? Was it posable that when the element burned though that it also damage the control unit? All other functions work on the control unit except the back cycle.
Ads By Google
Related Models
Amana AER5715QAQ Range - S/c F/s Ele
Amana AER5715QAS Range - S/c F/s Ele
Amana AER5715QAW Range - S/c F/s Ele
Amana AER5715QCB Range - S/c F/s Ele
Amana AER5715QCS Range - S/c F/s Ele
Amana AER5715QCW Range - S/c F/s Ele
Amana AER5715RCB Range - S/c F/s Ele
Amana AER5715RCS Range - S/c F/s Ele
Amana AER5715RCW Range - S/c F/s Ele
Amana AER5722BAB Range - S/c F/s Ele
Amana AER5722BAQ Range - S/c F/s Ele
Amana AER5722BAS Range - S/c F/s Ele
Amana AER5722BAW Range - S/c F/s Ele
Amana AER5722CAS Range - S/c F/s Ele
Amana AER5725QAB Range - S/c F/s Ele
Amana AER5725QAF Range - S/c F/s Ele
Amana AER5725QAN Range - S/c F/s Ele
Amana AER5725QAQ Range - S/c F/s Ele
Amana AER5725QAS Range - S/c F/s Ele
Amana AER5725QAW Range - S/c F/s Ele
Amana AER5735QAB Range - S/c F/s Ele
Amana AER5735QAF Range - S/c F/s Ele
Amana AER5735QAN Range - S/c F/s Ele
Amana AER5735QAQ Range - S/c F/s Ele
Amana AER5735QAS Range - S/c F/s Ele
Amana AER5735QAW Range - S/c F/s Ele
Amana AER5815RCB Range - S/c F/s Ele
Amana AER5815RCS Range - S/c F/s Ele
Amana AER5815RCW Range - S/c F/s Ele
Amana AER5845QAB Range - F/s Std Ele
Amana AER5845QAF Range - F/s Std Ele
Amana AER5845QAN Range - F/s Std Ele
Amana AER5845QAS Range - F/s Std Ele
Amana AER5845RAB Range - S/c F/s Ele
Amana AER5845RAS Range - S/c F/s Ele
Amana AER5845RAW Range - S/c F/s Ele
Amana AES1350BAW Range - S/c S/i Ele
General Electric AES15DAV1 Room air conditioner
General Electric AES18DAM1 Room air conditioner
General Electric AES23DAR1 Room air conditioner
Amana AES3540BAW Range - S/c S/i Gas
Amana AES3760BAB Range - S/c S/i Ele
Amana AES3760BAQ Range - S/c S/i Ele
Amana AES3760BAS Range - S/c S/i Ele
Amana AES3760BAW Range - S/c S/i Ele
Amana AES3760BCB Range - F/s Std Ele
Amana AES3760BCS Range - F/s Std Ele
Amana AES3760BCW Range - F/s Std Ele
Amana AES5730BAB Range - S/c S/i Ele
Amana AES5730BAF Range - S/c S/i Ele
Amana AES5730BAN Range - S/c S/i Ele
Amana AES5730BAS Range - S/c S/i Ele
Amana AET-480 Range - S/c S/i Ddraft Gas
Amana AET-480A Range - S/c S/i Ddraft Gas
Amana AET-480B Range - S/c S/i Ddraft Gas
Amana AET-480C Range - S/c S/i Ddraft Gas
General Electric AET05LHW1 Room air conditioner
General Electric AET05LJG1 Room air conditioner
General Electric AET05LJS1 Room air conditioner
General Electric AET05LJW1 Room air conditioner
Amana AEU-516 Range - S/c S/i Ddraft Gas
Amana AEU-516A Range - S/c S/i Ddraft Gas
Amana AEU-516C Range - S/c S/i Ddraft Gas
Amana AEU-516D Range - S/c S/i Ddraft Gas
Amana AEU-516E Range - S/c S/i Ddraft Gas
Amana AEU-516F Range - S/c S/i Ddraft Gas
Amana AEU-516G Range - S/c S/i Ddraft Gas
General Electric AEV24DJH1 Room air conditioner
General Electric AEV24DKH1 Room air conditioner
General Electric AEW05LJG1 Room air conditioner
General Electric AEW05LJS1 Room air conditioner
General Electric AEW05LJW1 Room air conditioner
General Electric AEW06LJG1 Room air conditioner
General Electric AEW06LJS1 Room air conditioner
General Electric AEW08AJS1 Room air conditioner
General Electric AEW10AJG1 Room air conditioner
General Electric AEW10AJS1 Room air conditioner
General Electric AEW24DHH1 Room air conditioner
General Electric AEW24DJH1 Room air conditioner
General Electric AEW24DKH1 Room air conditioner
Amana AEW3530DDB Walloven - S/c Ele
Amana AEW3530DDS Walloven - S/c Ele
Amana AEW3530DDW Walloven - S/c Ele
Amana AEW3630DDB Walloven - S/c Dbl Oven Ele
Amana AEW3630DDS Walloven - S/c Dbl Oven Ele
Amana AEW3630DDW Walloven - S/c Dbl Oven Ele
Amana AEW4530DDB Walloven - S/c Ele
Amana AEW4530DDQ Walloven - S/c Ele
Amana AEW4530DDS Walloven - S/c Ele
Amana AEW4530DDW Walloven - S/c Ele
Amana AEW4630DDB Walloven - S/c Dbl Oven Ele
Amana AEW4630DDQ Walloven - S/c Dbl Oven Ele
Amana AEW4630DDS Walloven - S/c Dbl Oven Ele
Amana AEW4630DDW Walloven - S/c Dbl Oven Ele
General Electric AEX08FAM1 Room air conditioner
Jenn-Air AEX918 Misc / Accessory
Thermador AF-7M
General Electric AF108FMP1 Room air conditioner
General Electric AF112DMW1 Room air conditioner
Admiral AF122 Freezer - Vertical
General Electric AF615DPE1 Room air conditioner
General Electric AF615DSE1 Room air conditioner
General Electric AF615DTE1 Room air conditioner
General Electric AF715DME1 Room air conditioner
General Electric AF812DMW1 Room air conditioner
General Electric AF812DNW1 Room air conditioner
General Electric AF908FMP3 Room air conditioner
General Electric AF908FMP4 Room air conditioner
General Electric AF908FSP1 Room air conditioner
General Electric AF908FTP1 Room air conditioner
General Electric AF908FWP1 Room air conditioner
General Electric AF910MBT1 Room air conditioner
General Electric AF910MST1 Room air conditioner
General Electric AF912AMW3 Room air conditioner
General Electric AF912AMW4 Room air conditioner
General Electric AF912ANW1 Room air conditioner
General Electric AF912ASW1 Room air conditioner
General Electric AF912DMW2 Room air conditioner
General Electric AF912DPW1 Room air conditioner
General Electric AF912DSW1 Room air conditioner
  #2 (permalink)
Old 03-20-2010, 03:17 PM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
Quote:
Ok, I assume that you have a meter. Kill the power to the oven, and pull the bake element out. Now, put one of your meter lead on one wire and the other laed on the other wire. Then turn the power on, and turn it on bake. If you read 120 volts, the new bake element is bad. If you don't read 120 volts accross the the 2 wires, you need a control. Tom ******************************************** - Parts
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Bake Element will not heat up Derswick Oven Repair (including Ranges and Cooktops) 1 01-31-2010 09:42 AM
Bake element does not heat jfm1234 Oven Repair (including Ranges and Cooktops) 0 12-09-2009 08:02 AM
bake element no heat rolf Oven Repair (including Ranges and Cooktops) 3 06-25-2009 09:59 PM
bake element will not heat pdqhale Oven Repair (including Ranges and Cooktops) 4 06-23-2009 05:26 PM
Bake element will not heat djmikey9 Oven Repair (including Ranges and Cooktops) 2 05-07-2009 11:51 AM
