Discuss
Amana electric Stove induction burners
 in
On my dual burner, the inside burner turns on and off. When its at a certain temp it shuts off
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Amana electric Stove induction burners
  #1 (permalink)
Old 05-26-2008, 03:15 PM
Junior Member
r17624 is on a distinguished road
Default Amana electric Stove induction burners
Model Number: ak2t30w2   Brand: Amana   Age: More than 10 years
On my dual burner, the inside burner turns on and off. When its at a certain temp it shuts off and this is after I ensured that the switch is turned off. It only ramps for about 5 secs but it does this 24/7.
Model number is 9709209760.
I was thinking that it might be the switch but I dont know because if I power off the entire unit from the breaker box, and then turn on after a couple of minutes, the burner will not turn on until I use it next. Is there a contoller, TC or switch issue.
I look up the switch with the model I have and Amana has obsolete the switch with know replace part identified.
Thanks in advance,
Mike
Ads By Google
Related Models
Amana AK2T30W2 Surface Unit - Ele
Amana AK2T35E Surface Unit - Ele
Amana AK2T35W Surface Unit - Ele
Amana AK2T36E1 Surface Unit - Ele
Amana AK2T36E2 Surface Unit - Ele
Amana AK2T36E4 Freezer - Chest
Amana AK2T36W1 Surface Unit - Ele
Amana AK2T36W2 Surface Unit - Ele
Amana AK3H30HRW Range - S/c S/i Ddraft Gas
Whirlpool AK4000XV0
Whirlpool AK4000XV1
Whirlpool AK4000XZ0
Whirlpool AK4000XZ1
Whirlpool AK4000XZ2
Amana AKC-1 Range - S/c S/i Ddraft Gas
Amana AKC-1B Range - S/c S/i Ddraft Gas
Amana AKC-2 Range - S/c S/i Ddraft Gas
Amana AKC-2B Range - S/c S/i Ddraft Gas
Amana AKC-2D Surface Unit - Ele
Amana AKC-3 Range - S/c S/i Ddraft Gas
Amana AKC-30S Range - S/c S/i Ddraft Gas
Amana AKC-35S Range - S/c S/i Ddraft Gas
Amana AKC-3B Range - S/c S/i Ddraft Gas
Amana AKC-4 Range - S/c S/i Ddraft Gas
Amana AKC-4B Range - S/c S/i Ddraft Gas
Amana AKC30C Surface Unit - Ele
Amana AKC30D Surface Unit - Ele
Amana AKC35C Surface Unit - Ele
Amana AKC35CB Surface Unit - Ele
Amana AKC35D Surface Unit - Ele
Amana AKD-1B Range - S/c S/i Ddraft Gas
Amana AKD1 Surface Unit - Ele
Amana AKD1B Surface Unit - Ele
Amana AKD2C Surface Unit - Ele
Amana AKD3C Surface Unit - Ele
Amana AKDE5E Surface Unit - Ele
Amana AKDE5WW Surface Unit - Ele
Amana AKDG1E Surface Unit - Gas
Amana AKDG1E1 Surface Unit - Gas
Amana AKDG1E2 Surface Unit - Gas
Amana AKDG1W Surface Unit - Gas
Amana AKDG1WW Surface Unit - Gas
Amana AKDG1WW1 Surface Unit - Gas
Amana AKDG2E Surface Unit - Gas
Amana AKDG2K Surface Unit - Gas
Amana AKDG2WW Surface Unit - Gas
Amana AKDH4C Surface Unit - Ele
Amana AKDH5E Surface Unit - Ele
Amana AKDH5W Surface Unit - Ele
Amana AKDH6E Surface Unit - Ele
Amana AKDH6WW Surface Unit - Ele
Amana AKE30 Surface Unit - Ele
Amana AKE30E2 Surface Unit - Ele
Amana AKE30W Surface Unit - Ele
Amana AKE30W2 Surface Unit - Ele
Amana AKE35 Surface Unit - Ele
Amana AKE35E2 Surface Unit - Ele
Amana AKE35W Surface Unit - Ele
Amana AKE35W2 Surface Unit - Ele
Amana AKED3050E Freezer - Chest
Amana AKED3050SS Freezer - Chest
Amana AKED3050WW Freezer - Chest
Amana AKED3060E Surface Unit - Ele
Amana AKED3060SS Surface Unit - Ele
Amana AKED3060WW Surface Unit - Ele
Amana AKEF3070E Surface Unit - Ele
Amana AKEF3070WW Surface Unit - Ele
Amana AKES3060E Surface Unit - Ele
Amana AKES3060WW Range - S/c S/i Ddraft Gas
Amana AKF-1 Range - S/c S/i Ddraft Gas
__________________
Michael T
  #2 (permalink)
Old 05-27-2008, 01:48 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Seems like a bad thermal cutoff in the dual burner, I would start by replacing the burner.
__________________
  #3 (permalink)
Old 05-29-2008, 11:00 AM
Junior Member
Smig is on a distinguished road
Default Dual burner problem
I have an Amana smoothtop range (Model #ARTS6651) and my dual burner is not working right. The 6" is out and the 9" went out but is now working again. I was going to replace the burners but not sure if its the burners or something else? Any advice is much appreicated.
  #4 (permalink)
Old 05-31-2008, 11:24 AM
Junior Member
Default
Thanks for the fast reply and suggestion. When looking at the schematic though, it appears that the switch should shut the thermal cutoff down.
Does the thermal cutoff bypass the switch?
__________________
Michael T
  #5 (permalink)
Old 05-31-2008, 12:15 PM
Senior Expert
APP Volunteer
Default
The thermal cutoff in the burner must be independent of the switch for safety reasons, preventing the glass from cracking due to overheating.
__________________
  #6 (permalink)
Old 01-04-2010, 04:08 PM
Junior Member
Default
I replaced the dual burner after hemming and hogging over the expense. I still have the same issue. Is it the switch now?
mike t
__________________
Michael T
  #7 (permalink)
Old 01-05-2010, 01:30 AM
Senior Expert
APP Volunteer
Default
Yes, I recently worked on the same stove and did the same thing as you did and found the switch was probably bad but due to the high cost, the customer threw it away. Found it very difficult to diagnose. In retrospect, I could have swapped the wiring to a known good burner, but it may have been difficult to do, too many wires.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
burners on stove top not working clark764 Oven Repair (including Ranges and Cooktops) 0 02-10-2010 05:41 PM
amana electric stove lock error zegilles Oven Repair (including Ranges and Cooktops) 0 01-31-2010 03:41 PM
ge stove top light on electric burners will not go out mjreisbord Oven Repair (including Ranges and Cooktops) 7 06-04-2009 09:23 PM
Fan Blades on Amana Induction Motor djhart9491 Heating, Ventilation, and Air Conditioning (HVAC) 0 05-18-2009 07:01 AM
Stove top gas burners do not light Duffyk Oven Repair (including Ranges and Cooktops) 3 12-03-2008 09:35 PM
