Discuss
Bake element not working - Broil is fine.
 in
Hello, I have a Frigidaire FEF365ASL range. Everything is working except the lower element. All of the stovetop burners function,
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Bake element not working - Broil is fine.
  #1 (permalink)
Old 03-10-2010, 09:21 PM
Junior Member
dank_01 is on a distinguished road
Default Bake element not working - Broil is fine.
Model Number: FEF365ASL   Brand: Frigidaire   Age: 5 - 10 years
Hello,
I have a Frigidaire FEF365ASL range. Everything is working except the lower element. All of the stovetop burners function, the broiler element heats, the clock, timer, and everything are just fine.
I tried the bake mode as well as the self-cleaning mode to get the element to heat.
I've removed the back panel, checked all of the wiring and connections, and in the process disconnected/reconnected the power. No change.
The problem started when I was baking bread and had the oven at 350. I briefly set the temp to 450 (the bread wasn't getting the right crust), then changed my mind and set it back to 350 (didn't want to burn the bottom with the element in preheat mode). I don't know if changing the temp up and down without giving the oven time to adjust the internal temp may have had something to do with it.
Are there any fuses on the time board that I might have set off? I've priced the board and they're either spendy or out-of-stock. I'm hoping there might be another solution or more troubleshooting I can do to determine the root of the problem.
Thank you in advance for assistance!
Dan
P.S. - the bread did finish cooking in the cooling oven (-:
Related Models
Frigidaire FEF365ASL Frigidaire/electric Range
Frigidaire FEF365BGDA Frg(v1) / Electric Range
Frigidaire FEF365BGDB Frg(v1) / Electric Range
Frigidaire FEF365BGDC Frg(v1) / Electric Range
Frigidaire FEF365BGDD ELECTRIC RANGE
Frigidaire FEF365BGDE Frigidaire/electric Range
Frigidaire FEF365BGWA Frg(v2) / Electric Range
Frigidaire FEF365BGWB Frg(v2) / Electric Range
Frigidaire FEF365BGWC Frg(v2) / Electric Range
Frigidaire FEF365BGWD ELECTRIC RANGE
Frigidaire FEF365BGWE Frigidaire/electric Range
Frigidaire FEF365BUA Frigidaire/electric Range
Frigidaire FEF365BUB Frigidaire/electric Range
Frigidaire FEF365BUC Frigidaire/electric Range
Frigidaire FEF365BUD Frigidaire/electric Range
Frigidaire FEF365BUE Frigidaire/electric Range
Frigidaire FEF365BUF Frigidaire/electric Range
Frigidaire FEF365BUG Frigidaire/electric Range
Frigidaire FEF365BUH Frigidaire/electric Range
Frigidaire FEF365BWA Frigidaire/electric Range
Frigidaire FEF365BWB Frigidaire/electric Range
Frigidaire FEF365BWC Frigidaire/electric Range
Frigidaire FEF365BWD Frigidaire/electric Range
Frigidaire FEF365BWE Frigidaire/electric Range
Frigidaire FEF365BWF Frigidaire/electric Range
Frigidaire FEF365BWG Frigidaire/electric Range
Frigidaire FEF365BWH Frigidaire/electric Range
Frigidaire FEF365BXCWA Frigidaire/electric Range
Frigidaire FEF365CGBA Frg(v3) / Electric Range
Frigidaire FEF365CGBB Frg(v3) / Electric Range
Frigidaire FEF365CGBC Frg(v3) / Electric Range
Frigidaire FEF365CGBD ELECTRIC RANGE
Frigidaire FEF365CGBE Frigidaire/electric Range
Frigidaire FEF365CGSA Frg(v4) / Electric Range
Frigidaire FEF365CGSB Frg(v4) / Electric Range
Frigidaire FEF365CGSC Frg(v4) / Electric Range
Frigidaire FEF365CGSD ELECTRIC RANGE
Frigidaire FEF365CGSE Frigidaire/electric Range
Frigidaire FEF365CGTA ELECTRIC RANGE
Frigidaire FEF365CGTC ELECTRIC RANGE
Frigidaire FEF365CGTD ELECTRIC RANGE
Frigidaire FEF365CGTE Frigidaire/electric Range
Frigidaire FEF365MXFCA Frigidaire/range
Frigidaire FEF365MXFCB Frigidaire/range
Frigidaire FEF365XESA Frigidaire/range
Frigidaire FEF365XESB Frigidaire/range
Frigidaire FEF366ABA Frigidaire/range
Frigidaire FEF366ABB Frigidaire/range
Frigidaire FEF366ABD Frigidaire/electric Range
Frigidaire FEF366ABE Frigidaire/electric Range
Frigidaire FEF366ABF Frigidaire/electric Range
Frigidaire FEF366AQA Frigidaire/range
Frigidaire FEF366ASA Frigidaire/range
Frigidaire FEF366ASB Frigidaire/range
Frigidaire FEF366ASC Frigidaire/electric Range
Frigidaire FEF366ASD Frigidaire/electric Range
Frigidaire FEF366ASE Frigidaire/electric Range
Frigidaire FEF366ASF Frigidaire/electric Range
Frigidaire FEF366ASG Frigidaire/electric Range
Frigidaire FEF366ASH Frigidaire/electric Range
Frigidaire FEF366ASJ Frigidaire/electric Range
Frigidaire FEF366ASK Frigidaire/electric Range
Frigidaire FEF366AUA Frigidaire/range
Frigidaire FEF366AUD Frigidaire/electric Range
Frigidaire FEF366AWA Frigidaire/range
Frigidaire FEF366AWD Frigidaire/electric Range
Frigidaire FEF366AWE Frigidaire/electric Range
Frigidaire FEF366AWF Frigidaire/electric Range
Frigidaire FEF366AWG Frigidaire/electric Range
Frigidaire FEF366AWH Frigidaire/electric Range
Frigidaire FEF366AWJ Frigidaire/electric Range
Frigidaire FEF366AWK Frigidaire/electric Range
Frigidaire FEF366BCA Frigidaire/electric Range
Frigidaire FEF366BCB Frigidaire/electric Range
Frigidaire FEF366BCC Frigidaire/electric Range
Frigidaire FEF366CASA Frg(v1) / Electric Range
Frigidaire FEF366CASB Frg(v2) / Electric Range
Frigidaire FEF366CBA Frigidaire/electric Range
Frigidaire FEF366CBB Frigidaire/electric Range
Frigidaire FEF366CBC Frigidaire/electric Range
Frigidaire FEF366CBD Frigidaire/electric Range
Frigidaire FEF366CBE Frigidaire/electric Range
Frigidaire FEF366CBF Frigidaire/electric Range
Frigidaire FEF366CBG Frigidaire/electric Range
Frigidaire FEF366CCA Frigidaire/electric Range
Frigidaire FEF366CCB Frigidaire/electric Range
Frigidaire FEF366CCC Frigidaire/electric Range
Frigidaire FEF366CCD Frigidaire/electric Range
Frigidaire FEF366CCE Frigidaire/electric Range
Frigidaire FEF366CCF Frigidaire/electric Range
Frigidaire FEF366CESA Frg(v1) / Electric Range
Frigidaire FEF366CESB Frg(v1) / Electric Range
Frigidaire FEF366CETA Frg(v2) / Electric Range
Frigidaire FEF366CETB Frg(v2) / Electric Range
Frigidaire FEF366CGSA Frg(v1) / Electric Range
Frigidaire FEF366CGSB Frg(v2) / Electric Range
Frigidaire FEF366CGSC Frg(v3) / Electric Range
Frigidaire FEF366CGSD Frg(v0) / Electric Range
Frigidaire FEF366CGSE Frg(v0) / Electric Range
Frigidaire FEF366CJSA Frigidaire/electric Range
Frigidaire FEF366CJSB Frigidaire/electric Range
Frigidaire FEF366CQA Frigidaire/electric Range
Frigidaire FEF366CQB Frigidaire/electric Range
Frigidaire FEF366CQC Frigidaire/electric Range
Frigidaire FEF366CQD Frigidaire/electric Range
Frigidaire FEF366CQE Frigidaire/electric Range
Frigidaire FEF366CQF Frigidaire/electric Range
Frigidaire FEF366CQG Frigidaire/electric Range
Frigidaire FEF366CSA Frigidaire/electric Range
Frigidaire FEF366CSB Frigidaire/electric Range
Frigidaire FEF366CSC Frigidaire/electric Range
Frigidaire FEF366CSD Frigidaire/electric Range
Frigidaire FEF366CSE Frigidaire/electric Range
Frigidaire FEF366CSF Frigidaire/electric Range
Frigidaire FEF366CSG Frigidaire/electric Range
Frigidaire FEF366DBA Frigidaire/electric Range
Frigidaire FEF366DBB Frigidaire/electric Range
Frigidaire FEF366DBE Frigidaire/range
Frigidaire FEF366DBH Frigidaire/range
Frigidaire FEF366DCA Frigidaire/electric Range
  #2 (permalink)
Old 03-10-2010, 11:09 PM
Junior Member
daniel2323 is on a distinguished road
Default bake element not working
Ussually when the bake element is not working but everything else is,its ussuallly just that element that needs to be replaced. The bake element is reletively easy to replace and inexpensive, it takes about 15 minutes. To be safe you can always check your thermostats with an ohm meter checking for continuity. 9 times out of 10 replace the element or pay a technician which my company charges about 150 and up for a ten minute job hope this helps
  #3 (permalink)
Old 03-11-2010, 03:05 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here is the wiring diagram for the unit.
http://manuals.frigidaire.com/prodin.../316255311.pdf
Id does not show any fuses etc. in the bake element circuit.
As daniel2323 said odds are it is the element.
They are usually between 20 to 30 ohms depending on wattage.
If it measures OK and since you have already checked the wiring then you will need a control board.
__________________
  #4 (permalink)
Old 03-11-2010, 07:44 AM
Junior Member
Default Another way to test....
Thank you both for your excellent advice.
As another method of testing, could I take the leads from the lower element and attach them to the broiler element? Then set the oven to bake and see if the top element heats?
It's just that I've never used an Ohm meter and am trying to avoid spending more money than I need.
If you think the meter is still the only way to do the test, I'll certainly read the sticky and try it that way, though.
Again, thank you very much for your assistance.
  #5 (permalink)
Old 03-11-2010, 08:17 AM
Junior Member
IHAA is on a distinguished road
Default
You can try that but I don't know if the broiler leads would be long enough to reach the element. You could always take it off and bring it to the back of the machine and then plug the element into the broil leads but that can be very dangerous. Best to just buy a cheap meter and check resistance. Usually you can see damage on a heating element that is bad but you need to check for sure if it's got the proper resistance. If it reads OL (out of limits) it's bad. If it reads 20-30 ohms, replace the control board like denman said. Good luck, and keep us posted.
  #6 (permalink)
Old 03-12-2010, 02:50 AM
Junior Member
Default element not working
Juging by what uve described I would say buy an ohm meter the more you try to rig a test the the greater chance of danger and damaging the product. From my experience and not seeing the appliance I would say it is either 1. The control board which I doubt ussually the appliance just completely fails not all the time but from my experience it fails. A control board is usually expeensive one of the most expensive on an appliance. 2. The element a good percentage of the time when u see a problem with an appliance like an element its the element that's directly responsible. Regardless if u want to check get an ohm meter its much safer. Also u can do searches on your model number and there are a lot of sights that give you step by step insrtuctions with pictures to help you. Hope it goes well
Daniel
  #7 (permalink)
Old 03-04-2012, 02:51 PM
Junior Member
JoelJames is on a distinguished road
Default Similar problem
We have model PGLEF385ES5.
The oven displayed F10 - out of control temperature. After that, the bake element is not working at all. Broil works fine.
We replaced the temperature sensor and the bake element. Still not working.
We've tested both elements, broil and bake. The broil element reads 21.1 ohms. The bake elements (both new and old) read 16.9 ohms.
Could both bottom elements be no good seeing as they don't read 20-30 ohms? Or is our next step to replace the EOC?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wall oven bake element not working! Broil works, clock works. ajachyra Oven Repair (including Ranges and Cooktops) 1 12-02-2009 06:30 AM
Replaced upper broil element, lower bake element. Elements still not working bumdout Oven Repair (including Ranges and Cooktops) 1 11-25-2009 02:49 PM
Oven bake/broil not working after bake element replacement J Justin Oven Repair (including Ranges and Cooktops) 1 11-05-2009 04:36 PM
Bake/Broil elements out, stove fine junkshooz Oven Repair (including Ranges and Cooktops) 3 08-31-2008 11:19 PM
No Bake, Broil, Conv other functions fine iouri Oven Repair (including Ranges and Cooktops) 3 01-16-2008 02:58 PM
