Getting an F-1 code. The code schedule solution says to replace the touch pad or clock. I can not ID a touch pad from the control panel module drawing. There is no p/n for a touch pad. I hesitate to disassemble the oven until I have the repair parts on hand. Anyone had this module apart or had any experience with the clock and face plate assembly?
Magician59, Thanks for the info. I had read the words off the page trying to find a "touch pad". It would be helpful if folks would ID parts using the manufacturer's nomenclature. At least now I can proceed based on your help.
Thanks once again, PCovey :)
