| » glass on oven door broken |
Model Number: gbd307pds2 Brand: Whirlpool Age: 1 - 5 years
The inside glass on the lower oven door has broke. How do I access this glass to repair? I have removed the screws on the inside panel but don't seem to be able to access the broken glass?
Replacement parts for WHIRLPOOL GBD307PDS2 | AppliancePartsPros.com 1. Remove the oven door from the oven (see the operators manual) 2. Place the oven door on a padded work surface with the front decorative glass facing down. I let the door handle hang over the edge so the door lays flat 3. Remove the two top door liner screws and the two door glass bracket screws (bottom of door), and lift the liner assembly off the decorative door glass and handle. 4. To remove the outer door glass: a) Remove the three outer glass holder screws and two outer glass bracket screws from the door liner. b) Lift the outer glass with the glass holder off the door liner. c) Remove the bracket. 5. To remove the center door glass, remove the bottom bracket, (it is loose), and slide the two top corners of the glass out of the door liner slots. 6. To remove the hinges and the inner door glass: NOTE: You will have to remove both hinges to remove the inner door glass from the oven door liner. a) Lift either side of the door liner, remove the two door hinge screws, and remove the hinge. b) Lift the other side of the door liner, remove the two screws for the other hinge, and remove the hinge. c) Lift the inner door glass liner cover off the liner. d) Remove the insulation and the inner door glass.
__________________
| Display Modes | |
| Broken Oven door glass | Mike-mcd | Oven Repair (including Ranges and Cooktops) | 5 | 02-04-2010 11:56 AM |
| broken inner glass on oven door | Broduer | Oven Repair (including Ranges and Cooktops) | 1 | 03-17-2009 07:48 PM |
| Oven door inner glass Broken | spealmann | Oven Repair (including Ranges and Cooktops) | 3 | 03-05-2009 02:57 PM |
| Do I need to fix it? Broken Oven Door Glass | cjrlauve | Oven Repair (including Ranges and Cooktops) | 7 | 02-25-2009 10:44 AM |
| broken oven door glass | abbyrubin | Oven Repair (including Ranges and Cooktops) | 1 | 11-28-2007 05:52 PM |
