I am having problems with holding temp when set I removed back and found sensor wire black looks burnt what do you think happened I am going to replace sensor hoping this is problem or anything you can tell me wouls help thanks
Test the sensor before you buy. Sometimes the wires char from the heat that works its way through and around the insulation.
