Discuss
error code
 in
getting a " 5 ab " error code on the display theres no tech sheet with stove ? Ads By
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » error code
  #1 (permalink)
Old 03-08-2010, 09:21 AM
Junior Member
angel fly is on a distinguished road
Default error code
Model Number: cg31600adv   Brand: Crosley   Age: 5 - 10 years
Ads By Google
Related Models
Crosley CG31600ADV Range - F/s Std Gas
Crosley CG3177VRV Range - F/s Std Gas
Crosley CG3177VUV Range - F/s Std Gas
Crosley CG3177XRA Range - F/s Std Gas
Crosley CG3177XRW Range - F/s Std Gas
Crosley CG3177XUA Range - F/s Std Gas
Crosley CG3177XUW Range - F/s Std Gas
Crosley CG3231XRA Range - F/s Cont Clean Gas
Crosley CG3231XRW Range - F/s Cont Clean Gas
Crosley CG3231XUA Range - F/s Cont Clean Gas
Crosley CG3231XUW Range - F/s Cont Clean Gas
Crosley CG34300ADA Range - S/c F/s Gas
Crosley CG34300ADT Range - S/c F/s Gas
Crosley CG34300ADW Range - S/c F/s Gas
Crosley CG3432SRA Range - S/c F/s Gas
Crosley CG3432SRW Range - S/c F/s Gas
Crosley CG3432XRA Range - S/c F/s Gas
Crosley CG3432XRW Range - S/c F/s Gas
Crosley CG3438SRA Range - S/c F/s Gas
Crosley CG3438SRW Range - S/c F/s Gas
Crosley CG34700ADD Range - S/c F/s Gas
Crosley CG34700ADQ Range - S/c F/s Gas
Crosley CG34700ADV Range - S/c F/s Gas
Crosley CG34700BDQ Range - S/c F/s Gas
Crosley CG34700BDT Range - S/c F/s Gas
Crosley CG34700BDV Range - S/c F/s Gas
Crosley CG34700BDW Range - S/c F/s Gas
Crosley CG3478VVD Range - S/c F/s Gas
Crosley CG3478VVV Range - S/c F/s Gas
Crosley CG3478XRA Range - S/c F/s Gas
Crosley CG3478XRW Range - S/c F/s Gas
Crosley CG3478XVA Range - S/c F/s Gas
Crosley CG3478XVW Range - S/c F/s Gas
Crosley CG34800ADQ Range - F/s Std Gas
Crosley CG34800ADS Range - F/s Std Gas
Crosley CG34800ADT Range - F/s Std Gas
Crosley CG34800ADV Range - F/s Std Gas
Crosley CG34800ADW Range - F/s Std Gas
Crosley CG34800BDS Range - S/c F/s Gas
Crosley CG4131WRA Range - F/s Std Gas
Crosley CG4131WRW Range - F/s Std Gas
Crosley CG4151WTA Range - F/s Std Gas
Crosley CG4151WTW Range - F/s Std Gas
Hardwick CG4612MA539RG Range - F/s Std Gas
Hardwick CG4612MW539RG Range - F/s Std Gas
Hardwick CG4616MA429RG Range - F/s Std Gas
Hardwick CG4616MW429RG Range - F/s Std Gas
Hardwick CG4622MA429RG Range - F/s Std Gas
Hardwick CG4622MA439RG Range - F/s Std Gas
Hardwick CG4622MA539RG Range - F/s Std Gas
Hardwick CG4622MW429RG Range - F/s Std Gas
Hardwick CG4622MW439RG Range - F/s Std Gas
Hardwick CG4622MW539RG Range - F/s Std Gas
Hardwick CG4622MY539RG Range - F/s Std Gas
Hardwick CG4642MA639RG Range - F/s Std Gas
Hardwick CG4642MW639RG Range - F/s Std Gas
Crosley CG6498VVA Range - S/c S/i Gas
Crosley CG6498VVV Range - S/c S/i Gas
Hardwick CG7241A819R Walloven - Cont Clean Gas
Crosley CG8211PA Surface Unit - Gas
Crosley CG8211PS Surface Unit - Gas
Crosley CG8211PW Surface Unit - Gas
Amana CG8409W Dryer - Gas
Amana CG8409W2 Dryer - Gas
Hardwick CG8422MA729RG Walloven - Std Dbl Oven Gas
Hardwick CG8422MW729RG Walloven - Std Dbl Oven Gas
Hardwick CG8422MY729RG Walloven - Std Dbl Oven Gas
Crosley CG9222XPB Walloven - Cont Clean Gas
Hardwick CG9441B9R Range - D/i Std Gas
Hardwick CG9616A429R Range - F/s Std Gas
Hardwick CG9616A429RW Range - F/s Std Gas
Hardwick CG9616A79R Range - F/s Std Gas
Hardwick CG9616W429R Range - F/s Std Gas
Hardwick CG9616W429RW Range - F/s Std Gas
Hardwick CG9616W79R Range - F/s Std Gas
Hardwick CG9617A439R Range - F/s Std Gas
Hardwick CG9617W439R Range - F/s Std Gas
Hardwick CG9617W540R Range - F/s Std Gas
Hardwick CG9617W540RG Range - F/s Std Gas
Hardwick CG9617W540RQ Range - F/s Std Gas
Hardwick CG9617W560RQ Range - F/s Std Gas
Hardwick CG9617W570R Range - F/s Std Gas
Hardwick CG9621A539R Range - F/s Std Gas
Hardwick CG9621W539R Range - F/s Std Gas
Frigidaire CGA1M2WE Gib(v2) / Gas Range
Frigidaire CGA1M2WSE Gib(v1) / Gas Range
Frigidaire CGA1M2WSTA Gib(v1) / Free Standing Gas Range
Frigidaire CGA1M2WSTB Gib(v2) / Free Standing Gas Range
Frigidaire CGA1M2WSTC Gib(v1) / Gas Range
Frigidaire CGA1M2WSTD Gib(v1) / Gas Range
Frigidaire CGA1M3WSTA Gib(v3) / Free Standing Gas Range
Frigidaire CGA1M3WSTB Gib(v1) / Gas Range
Crosley CGA2D2 Range - F/s Std Gas
Crosley CGA2D21 Range - F/s Std Gas
Crosley CGA2D2K Range - F/s Std Gas
Crosley CGA2D2K-1 Range - F/s Std Gas
Crosley CGA3C6CLVK Range - F/s Cont Clean Gas
Crosley CGA3C6CVK Range - F/s Std Gas
Crosley CGA3D1 Range - F/s Std Gas
Crosley CGA3D1K Range - F/s Std Gas
Crosley CGA3D1X Range - F/s Std Gas
Crosley CGA3D3WK Range - F/s Std Gas
Crosley CGA3D3X Range - F/s Std Gas
Crosley CGA3D5VK Range - F/s Std Gas
Crosley CGA3D5WK Range - F/s Std Gas
Crosley CGA3D5XK Range - F/s Std Gas
Crosley CGA3D6CLVK Range - F/s Cont Clean Gas
Crosley CGA3D6CSVK Range - F/s Std Gas
Crosley CGA3D6CSVK-1 Range - F/s Std Gas
Crosley CGA3D6CVK Range - F/s Std Gas
Frigidaire CGA3M2WSTA Gib(v4) / Free Standing Gas Range
Frigidaire CGA3M2WSTB Gib(v5) / Free Standing Gas Range
Frigidaire CGA3M2WSTC Gib(v6) / Free Standing Gas Range
Frigidaire CGA3M2WSTD Gib(v1) / Gas Range
Crosley CGA4C58CZKW Range - S/c F/s Gas
Crosley CGA4D59EZK Range - S/c F/s Gas
Crosley CGA4D59TSK-1 Range - S/c F/s Gas
Crosley CGA4D59TSZK Range - S/c F/s Gas
Crosley CGA4D59TZK Range - S/c F/s Gas
Crosley CGA6C5GWK Range - F/s Std Gas
  #2 (permalink)
Old 03-08-2010, 12:43 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Your oven is in "Sabbath" mode. You'll need to consult your user manual to cancel it.
  #3 (permalink)
Old 03-09-2010, 05:37 AM
Junior Member
Default sabbath mode
what is sabbath mode ? and there is no manual sorry how to reset if it can be reset
  #4 (permalink)
Old 03-09-2010, 12:40 PM
Senior Expert
APP Volunteer
Default
Sabbath mode has to do with the Jewish faith and the way they plan their weekend to rest and worship on the Sabbath (Which means "rest"). Try pressing and holding "CLOCK" for three to five seconds. You should get your display back.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
F2 error code kayakcrzy Washer Repair 10 05-10-2011 09:54 PM
frigidaire error code F10 - not listed in your error codes Skully26 Oven Repair (including Ranges and Cooktops) 2 02-16-2010 04:29 AM
Error code F2-E9 Craig Hughes Oven Repair (including Ranges and Cooktops) 1 10-02-2009 09:32 PM
F-1 error code k8mp Oven Repair (including Ranges and Cooktops) 0 09-21-2009 07:44 AM
FR Error Code ovsanna Oven Repair (including Ranges and Cooktops) 0 01-01-2009 09:08 AM
