Discuss
Lifting Stovetop to replace ignitor
 in
I have a Hotpoint RGB745GES1 that works fine except that one burner doesn't ignite; the other three do. I suspect
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Lifting Stovetop to replace ignitor
  #1 (permalink)
Old 03-08-2010, 07:11 AM
Junior Member
rpixley is on a distinguished road
Default Lifting Stovetop to replace ignitor
Model Number: RBG745GES1WH   Brand: Hotpoint   Age: More than 10 years
I have a Hotpoint RGB745GES1 that works fine except that one burner doesn't ignite; the other three do. I suspect its the ignitor, but I want to take a look at what's under to stovetop to see if there is something else of concern before ordering parts. But I can't figure out how to lift the stovetop. Where would I find this information?
Ads By Google
Related Models
Frigidaire RBGF119E1 BLACK Frg(v8) / Electric Cooktops and Control Box
Frigidaire RBGF119EL1 Frg(v7) / Electric Cooktops and Control Box
Frigidaire RBGF119EW1 Frg(v6) / Electric Cooktops and Control Box
Amana RBK22AA0 Range - S/i Std Gas
Amana RBK22AA093M Range - S/i Std Gas
Amana RBK22AA5 Range - S/i Std Gas
Amana RBK22AAL Range - S/c S/i Ddraft Gas
Amana RBK22AAW Range - S/c S/i Ddraft Gas
Amana RBK24AA Range - S/i Std Gas
Amana RBK24AA0 Range - S/i Std Gas
Amana RBK24AA093M Range - S/i Std Gas
Amana RBK24AA5 Range - S/i Std Gas
Amana RBK24AAL Range - S/c S/i Ddraft Gas
Amana RBK24AAW Range - S/c S/i Ddraft Gas
Amana RBK26AA Range - S/i Std Gas
Amana RBK26AA0 Range - S/i Std Gas
Amana RBK26AA093M Range - S/i Std Gas
Amana RBK26AA5 Range - S/i Std Gas
Amana RBK26AAL Range - S/c S/i Ddraft Gas
Amana RBK26AAW Range - S/c S/i Ddraft Gas
Amana RBK26CBL Range - S/c S/i Ddraft Gas
Amana RBK26CBW Range - S/c S/i Ddraft Gas
Amana RBK28FG Range - S/i Std Gas
Amana RBK28FG0 Range - S/i Std Gas
Amana RBK28FG5 Range - F/s Std Gas
Maytag RBK28FG5  Range - F/s Std Gas
Amana RBK28FGL Range - S/c S/i Ddraft Gas
Amana RBK28FGW Range - S/c S/i Ddraft Gas
Amana RBK29AA093M Range - S/i Std Gas
Amana RBK29AAL Range - S/c S/i Ddraft Gas
Amana RBK29AAW Range - S/c S/i Ddraft Gas
Amana RBL22AAL Range - S/c S/i Ddraft Gas
Amana RBL22AAW Range - S/c S/i Ddraft Gas
Amana RBL26AAL Range - S/c S/i Ddraft Gas
Amana RBL26AAW Range - S/c S/i Ddraft Gas
Amana RBL39AA0,5 Range - S/c S/i Ddraft Gas
Amana RBL39AA05 Range - S/c S/i Ddraft Gas
Amana RBP22AA0 Range - S/c S/i Ddraft Gas
Amana RBP22AA5 Range - S/c S/i Ddraft Gas
Amana RBP22AAL Range - S/c S/i Ddraft Gas
Amana RBP22AAW Range - S/c S/i Ddraft Gas
Amana RBP24AA0 Range - S/i Std Gas
Amana RBP24AA5 Range - S/c S/i Ddraft Gas
Amana RBP24AAL Range - S/c S/i Ddraft Gas
Amana RBP24AAW Range - S/c S/i Ddraft Gas
Amana RBP26AA0 Range - S/i Std Gas
Amana RBP26AA5 Range - S/i Std Gas
Amana RBP26AAL Range - S/c S/i Ddraft Gas
Amana RBP26AAW Range - S/c S/i Ddraft Gas
Amana RBP26CBL Range - S/c S/i Ddraft Gas
Amana RBP26CBW Range - S/c S/i Ddraft Gas
Amana RBP26ZZ Range - S/i Std Gas
Amana RBP29AA0 Range - S/i Std Gas
Amana RBP29AA5 Range - S/i Std Gas
Amana RBP29AAL Range - S/c S/i Ddraft Gas
Amana RBP29AAW Range - S/c S/i Ddraft Gas
Amana RBP39AA0,5 Range - S/c S/i Ddraft Gas
  #2 (permalink)
Old 03-08-2010, 01:02 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
You gotta start by disconnecting the burner assemblies from the stove top. Otherwise, you'll kink the gas lines to them, or possibly break them. Once all the burners are free, just lift the front of the stove top.
  #3 (permalink)
Old 03-08-2010, 02:11 PM
Junior Member
Default
Two torus screws per burner? Is there a drawing or sketch somewhere that shows the orientation of the gas line? (Kinking the gas line is one of my first concerns, which is why I ask before trying.)
  #4 (permalink)
Old 03-08-2010, 02:43 PM
Senior Expert
APP Volunteer
Default
I couldn't find a breakdown drawing; but if you remove the screws that hold the burners to the stovetop, you should be able to lift it. The screws are
T15 or T20 Torx.
  #5 (permalink)
Old 03-09-2010, 11:21 AM
Junior Member
Default
I go the torox screws off (there were 3, not 2) and lifted the round thingies. The round thingies sat on the gas pipe and had a wire attached to it.
(For those reading this, have a plan for preventing the screws from falling into the just opened hole such as taking the screws completely off the stovetop and store them away from the stovetop before making any movement on the round thingy to loosen it. And before bringing the screw back to to stove, make sure there are no holes they could fall into. That misfortune didn't happen to me, but I can see it readily happenning to someone else.)
I still couldn't lift the stove top, but that may not be needed. I did note the electrode on the burners that lights up intermittantly seem more corroded than those that light up all the time, but the wire leading up to it appears to still be new. It also makes sense, those burners have more exposure to accidental spills than the ones that consistently work, so that is probably the cause. So the obvious question now is: How do I repair or replace those electrodes, and can it be done without opening up the hood?
I took some photos before reassembling, in case they may be needed.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
need to replace ignitor surface gerald54 Oven Repair (including Ranges and Cooktops) 0 08-29-2009 03:01 AM
Removing knobs to replace ignitor? TerryCook Oven Repair (including Ranges and Cooktops) 0 08-27-2009 08:34 AM
Need to replace wiring harness on electric stovetop blarzelere Oven Repair (including Ranges and Cooktops) 0 05-30-2009 08:42 PM
Stovetop ignitor (electrode) GM18 Oven Repair (including Ranges and Cooktops) 3 12-09-2008 05:53 PM
Stovetop ignitor failure 35ametrineway Oven Repair (including Ranges and Cooktops) 1 07-22-2008 04:07 PM
