Discuss
reattching oven door
 in
As I was pulling the oven out to get behind it the door came off. now i cant get the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » reattching oven door
  #1 (permalink)
Old 05-24-2008, 01:04 PM
Junior Member
teacher95864 is on a distinguished road
Default reattching oven door
Brand: Whirlpool   Age: More than 10 years
As I was pulling the oven out to get behind it the door came off. now i cant get the hinges to cooperate in getting it back on. the srpings are still strong because i cant keep the at the 1st stop long enough to hook it back on. what do i do to get this door back on?
Ads By Google
  #2 (permalink)
Old 05-24-2008, 07:08 PM
Junior Member
jeffalex2 is on a distinguished road
Default Have a broom stick?...
...or a small board...keep your fingers away from the spring hinges. Use a large pair of plyers/channel locks to pry the hinges down far enough to get a broom stick or board stuck in the hinges. Do one at a time. Once the hinges are stuck open far enough, slide the door back on. Then, use the door to open the hinges up and take out the stick.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn Aire Micro/Oven combo, oven door does not shut tight dsazama Oven Repair (including Ranges and Cooktops) 5 03-13-2012 11:29 AM
Oven Door Latch Locked W/O Door hseeger Oven Repair (including Ranges and Cooktops) 7 04-04-2011 06:15 PM
The inner section of my oven door has become removed from the oven door.Can i reseal? Will O Oven Repair (including Ranges and Cooktops) 3 12-01-2009 04:07 AM
My oven door won't stay shut and the light stays on. The door is loose. Vanise Oven Repair (including Ranges and Cooktops) 2 03-24-2008 11:36 AM
My Oven Door Latch Won't unlock so the door won"t close Victorine Ravenell Oven Repair (including Ranges and Cooktops) 1 11-14-2007 10:40 AM
