After boiling water cooktop stopped working after loud popping noise, which tripped the electrical breaker. Loud pop once breaker reset, there is an electrical smell but upon initial visual inspection of the element switches, wiring and fuse breakers all seems ok. However nothing works, fan will not turn on nor either of the elements.
I
