Discuss
Frigidaire Electric Range
 in
Dear Sirs, I own the above model Frigidaire, can anyone tell me how to check the dual element switch? Both
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Frigidaire Electric Range
  #1 (permalink)
Old 05-23-2008, 12:40 PM
Schnidly Schnidly is offline
Junior Member
Schnidly is on a distinguished road
Default Frigidaire Electric Range
Model Number: REGC39BNW2   Brand: Frigidaire   Age: More than 10 years
Dear Sirs,
I own the above model Frigidaire, can anyone tell me how to check the dual element switch? Both the inside and outside burner comes on no matter which direction the control knob is turned. Also, can someone give me directions on how to replace the old switch with the new one, are there any concerns for me to understand before tearing apart the back panel of the range? Also, does someone know how to calibrate the oven? I dont have a thermometer that reads that high to calibrate with, any suggestions?
Thanks so much
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-23-2008, 04:21 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
According to your description of the problem with the dual element the switch is bad and does not need any further diagnosis.
In order to calibrate the oven temperature you have to have a good oven thermometer.
- The part number for the dual element switch is AP2141123
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Electric Oven Doesn't Heat sharzaz Oven Repair (including Ranges and Cooktops) 9 11-03-2008 02:00 PM
Electric range mamu Oven Repair (including Ranges and Cooktops) 0 04-03-2008 12:40 PM
Frigidaire electric dryer outlaw Dryer Repair 1 01-19-2008 07:42 PM
Electric Range TREFFJ Oven Repair (including Ranges and Cooktops) 4 01-15-2008 12:35 PM
Frigidaire Electric Range Heating Element Replacement johnhmon Oven Repair (including Ranges and Cooktops) 0 10-06-2007 05:14 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
