Discuss
GE 4 burner gas cooktop
 in
My cermamic top cracked. I bought a replacement top. To remove and replace do you just remove the torx screw
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE 4 burner gas cooktop
  #1 (permalink)
Old 05-23-2008, 11:25 AM
Junior Member
88foothill is on a distinguished road
Default GE 4 burner gas cooktop
Model Number: JGP932KED2CC   Brand: GE   Age: 1 - 5 years
My cermamic top cracked. I bought a replacement top. To remove and replace do you just remove the torx screw from the center of each burner? Also, the igniter, will the cooktop lift off over it or do you have to disconnect a wire from the bottom of the igniter. What is the correct procedure to replace the glass top? Thx
Ads By Google
Related Models
General Electric JGP932KED2CC Gas range
General Electric JGP932SEC1SS Gas range
General Electric JGP932SEC2SS Gas range
General Electric JGP932TEC1WW Gas range
General Electric JGP932TEC2WW Gas range
General Electric JGP933BEC1BB Gas range
General Electric JGP933BEC2BB Gas range
General Electric JGP933BEJ1BB Gas range
General Electric JGP933BEK1BB Gas range
General Electric JGP933BEK2BB Gas range
General Electric JGP933CEC1CC Gas range
General Electric JGP933CEC2CC Gas range
General Electric JGP933CEJ1CC Gas range
General Electric JGP933CEK1CC Gas range
General Electric JGP933CEK2CC Gas range
General Electric JGP933SEC1SS Gas range
General Electric JGP933SEC2SS Gas range
General Electric JGP933SEJ1SS Gas range
General Electric JGP933SEK1SS Gas range
General Electric JGP933SEK2SS Gas range
General Electric JGP933WEC1WW Gas range
General Electric JGP933WEC2WW Gas range
General Electric JGP933WEJ1WW Gas range
General Electric JGP933WEK1WW Gas range
General Electric JGP933WEK2WW Gas range
General Electric JGP940BEK1BB Gas range
General Electric JGP940BEK2BB Gas range
General Electric JGP940KEK1CC Gas range
General Electric JGP940KEK2CC Gas range
General Electric JGP940SEK1SS Gas range
General Electric JGP940SEK2SS Gas range
General Electric JGP940TEK1WW Gas range
General Electric JGP940TEK2WW Gas range
General Electric JGP945BEK1BB Gas range
General Electric JGP945BEK2BB Gas range
General Electric JGP945CEK1CC Gas range
General Electric JGP945CEK2CC Gas range
General Electric JGP945SEK1SS Gas range
General Electric JGP945SEK2SS Gas range
General Electric JGP945WEK1WW Gas range
General Electric JGP945WEK2WW Gas range
General Electric JGP960SEA1SS Gas range
General Electric JGP960SED1SS Gas range
General Electric JGP962BEC1BB Gas range
General Electric JGP962BEC2BB Gas range
General Electric JGP962CEC1CC Gas range
General Electric JGP962KED2CC Gas range
General Electric JGP962SEC1SS Gas range
General Electric JGP962SEC2SS Gas range
General Electric JGP962TEC1WW Gas range
General Electric JGP962TEC2WW Gas range
General Electric JGP963BEC1BB Gas range
General Electric JGP963BEC2BB Gas range
General Electric JGP963BEJ1BB Gas range
General Electric JGP963BEK1BB Gas range
General Electric JGP963BEK2BB Gas range
General Electric JGP963CEC1CC Gas range
General Electric JGP963CEC2CC Gas range
General Electric JGP963CEJ1CC Gas range
General Electric JGP963CEK1CC Gas range
General Electric JGP963CEK2CC Gas range
General Electric JGP963SEC1SS Gas range
General Electric JGP963SEC2SS Gas range
General Electric JGP963SEF1SS Gas range
General Electric JGP963SEJ1SS Gas range
General Electric JGP963SEK1SS Gas range
General Electric JGP963SEK2SS Gas range
General Electric JGP963WEC1WW Gas range
General Electric JGP963WEC2WW Gas range
General Electric JGP963WEJ1WW Gas range
General Electric JGP963WEK1WW Gas range
General Electric JGP963WEK2WW Gas range
General Electric JGP970BEK1BB Gas range
General Electric JGP970BEK2BB Gas range
General Electric JGP970KEK1CC Gas range
General Electric JGP970KEK2CC Gas range
General Electric JGP970SEK1SS Gas range
General Electric JGP970SEK2SS Gas range
General Electric JGP970TEK1WW Gas range
General Electric JGP970TEK2WW Gas range
General Electric JGP975BEK1BB Gas range
General Electric JGP975BEK2BB Gas range
General Electric JGP975CEK1CC Gas range
General Electric JGP975CEK2CC Gas range
General Electric JGP975SEK1SS Gas range
General Electric JGP975SEK2SS Gas range
General Electric JGP975WEK1WW Gas range
General Electric JGP975WEK2WW Gas range
General Electric JGP979BEF1BB Gas range
General Electric JGP979BEF2BB Gas range
General Electric JGP979SEF1SS Gas range
General Electric JGP979SEF2SS Gas range
General Electric JGP979WEF1WW Gas range
General Electric JGP979WEF2WW Gas range
General Electric JGP985BEJ1BB Gas range
General Electric JGP985SEJ1SS Gas range
General Electric JGP985WEJ1WW Gas range
General Electric JGP989BC1BB Gas range
General Electric JGP989BC2BB Gas range
General Electric JGP989BC3BB Gas range
General Electric JGP989BC4BB Gas range
General Electric JGP989BK1BB Gas range
General Electric JGP989BK2BB Gas range
General Electric JGP989KC1CC Gas range
General Electric JGP989KC2CC Gas range
General Electric JGP989KC3CC Gas range
General Electric JGP989KC4CC Gas range
General Electric JGP989KK1CC Gas range
General Electric JGP989KK2CC Gas range
General Electric JGP989TC1WW Gas range
General Electric JGP989TC2WW Gas range
General Electric JGP989TC3WW Gas range
General Electric JGP989TC4WW Gas range
General Electric JGP989TK1WW Gas range
General Electric JGP989TK2WW Gas range
General Electric JGP990BEL1BB Gas range
General Electric JGP990SEL1SS Gas range
General Electric JGP990WEL1WW Gas range
Jenn-Air JGR8730ADQ Range - S/c F/s Gas
Jenn-Air JGR8730ADW Range - S/c F/s Gas
  #2 (permalink)
Old 05-28-2008, 10:34 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
Yes, remove the torx screws. If you pull up on the burner after the screws are removed, you will loosen the ignitor enough to pull it straight up. each ignitor has 1 wire hooked to it. remove the wires. Remove old cooktop, run wires up through the new glass, put burners back on and screw in. attach wires to ignitors and push back through hole, and your done...Pretty easy. Takes me 10 minutes tops to replace those.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cooktop Burner Control Light ON when Burner if OFF isimek@remedymd.com Oven Repair (including Ranges and Cooktops) 2 01-29-2011 10:48 PM
Whirlpool Cooktop Gas Burner Box brillianthappiness Oven Repair (including Ranges and Cooktops) 0 10-15-2009 03:42 PM
cooktop burner dfelske Oven Repair (including Ranges and Cooktops) 1 01-12-2009 05:06 PM
cooktop burner comes on only high steve2008 Oven Repair (including Ranges and Cooktops) 1 01-09-2009 05:12 AM
Cooktop No Gas To One Burner???? Daltex Oven Repair (including Ranges and Cooktops) 2 01-06-2009 03:48 PM
