The bake burner on the oven has a crack in it next to where the igniter is. When the oven is turned on the flame sputters and isn't how strong it should be. This has been going on for a little over a week. Was the crack cause by the oven not igniting the right way or is it the gas valve that is bad and caused the crack due to a miss fire? Thanks Duke
