| » Oven lites intermitantly |
Model Number: SF315PEKB0 Brand: Whirlpool Age: 1 - 5 years
On oven control, push bake & start, a 10 minute warm-up starts with the igniter glowing brightly, at the end of the 10 min. the timer dings and the display shows 350 deg temperature setting, but no ignition. Waited a couple more minutes and still nothing. Unplugged the range to see if it would reset it's self (5 Min) then tried again with same results. After a few minutes, I tried the old Army trick and tapped on the oven valve and behold there was ignition. Was this coinsidence or is the valve defective.
Earl,
Measure the current drawn by the oven igniter. If it more than 3.2 amps then the problem is a bad gas valve. If it's 3.2 amps or less then the problem is a bad igniter. - The part number for the oven igniter is AP3129373 - The part number for the gas safety valve is AP3129369 Here are the break down diagrams for the Whirlpool range Model SF315PEKB0 Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| oven wont lite, tap on valve, lites 30 secounds later shuts off | in need of help | Oven Repair (including Ranges and Cooktops) | 0 | 01-05-2010 02:44 PM |
| Ignitor lites oven but shuts off | Henry Waring | Oven Repair (including Ranges and Cooktops) | 1 | 08-13-2009 12:51 PM |
| oven lites but doe not get hot ,small flame | smitty8852 | Oven Repair (including Ranges and Cooktops) | 1 | 04-26-2009 03:24 PM |
| Ignitor keeps clicking until oven lites or I unplug them | timbo1961 | Oven Repair (including Ranges and Cooktops) | 0 | 04-06-2009 10:23 AM |
| Built In Oven Lites Turns Off Immediately | jrina0enteria46@yahoo.com | Oven Repair (including Ranges and Cooktops) | 1 | 11-15-2008 03:22 PM |
