mase
#1 Posted : Sunday, February 28, 2010 12:36:00 PM(UTC)
mase
The broiler element exploded near the plug at the back of the oven. I have purchased and installed a new element. I'm am getting no power to the broiler element. Any ideas on what the problem could be.
Thanks,
Mase
#2 Posted : Monday, March 1, 2010 1:45:23 AM(UTC)
Replacement parts for WHIRLPOOL RBS245PDS17 24" Built - in Electric Single Oven Self - Clean | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208301758.pdf
If both broil and bake do not come on then the Thermostat Item 37 i Section 1 may be open.
If it is just the broil element then unfortunately it is probably the control board.
I would check the wiring to the broil element just to be sure that a wire has not burned off.
Whirlpool Accubake Oven Not Working (Oven Repair (including Ranges and Cooktops))
by buddha61 11/15/2017 5:18:32 PM(UTC)
outer door installation on whirlpool accubake oven (Oven Repair (including Ranges and Cooktops))
by rldaustin 6/16/2014 4:15:59 AM(UTC)
Whirlpool Accubake Oven Clock display issue (Oven Repair (including Ranges and Cooktops))
by jimkenzie 2/24/2014 7:48:06 PM(UTC)
Whirlpool accubake oven isnt working (Oven Repair (including Ranges and Cooktops))
by chrisdod84 1/18/2013 12:16:23 PM(UTC)
Whirlpool Accubake Oven Problem (Oven Repair (including Ranges and Cooktops))
by 951prerun 6/6/2012 6:35:57 PM(UTC)
Whirlpool accubake oven door locking problem (Oven Repair (including Ranges and Cooktops))
by ZDM 10/16/2011 8:53:11 AM(UTC)
Whirlpool Gold Accubake Oven won't attain temperature (Oven Repair (including Ranges and Cooktops))
by sandy1951 1/7/2011 7:46:50 PM(UTC)
accubake oven won't heat up (Oven Repair (including Ranges and Cooktops))
by xxx xxx xxx 10/13/2010 6:48:51 AM(UTC)
Whirlpool Accubake Oven Is Not Working (Oven Repair (including Ranges and Cooktops))
by peteshellz 7/20/2010 3:57:53 AM(UTC)
Whirlpool Gold Accubake oven error code E0 -F2- (Oven Repair (including Ranges and Cooktops))
by sajajea 9/25/2009 10:06:32 PM(UTC)
by lisaslusher 4/6/2008 12:46:48 PM(UTC)
