mark s
#1 Posted : Sunday, February 28, 2010 10:27:38 AM(UTC)
mark s
Need a little help with the wiring. There are 3 wires that enter through a hole in the rear of the oven. blue, white, and yellow. The yellow is on the igniter. The white and blue are on the top of the gas valve. The white wire jumps from the top of the valve to the bottom of the valve. The other wire on the bottom of the gas valve is on the igniter. How do I check the gas valve?
Whirlpool GW397LXUS06 - 1 igniter not working (Oven Repair (including Ranges and Cooktops))
by TommyBoy2323 2/14/2021 8:56:10 AM(UTC)
Auto igniter not working on GE gas range (Oven Repair (including Ranges and Cooktops))
by saiprasad 6/28/2012 4:36:35 PM(UTC)
Kenmore Elite igniter not working properly (Oven Repair (including Ranges and Cooktops))
by hawknlv 10/28/2010 5:13:37 PM(UTC)
Burner igniter not working oven won't heat past 300 (Oven Repair (including Ranges and Cooktops))
by Chet Wajda 3/8/2009 7:45:32 AM(UTC)
by Chet Wajda 3/8/2009 7:40:10 AM(UTC)
Jenn-Air Igniter not working (Oven Repair (including Ranges and Cooktops))
by pksocal 8/30/2008 7:38:06 PM(UTC)
