Discuss
how to check door lock circuit
 in
Getting an F9 error. The charts I've read say to check the door lock circuit. How do you do
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » how to check door lock circuit
  #1 (permalink)
Old 05-19-2008, 03:35 PM
TrishK TrishK is offline
Junior Member
TrishK is on a distinguished road
Default how to check door lock circuit
Model Number: CGR3742CDC   Brand: Magic Chef   Age: 1 - 5 years
Getting an F9 error. The charts I've read say to check the door lock circuit. How do you do that?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-20-2008, 03:46 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Check the switch on the door latch for continuity. It should be closed when the door is locked and open when the door is unlocked.
If there is nothing wrong then the electronic oven control (aka clock) has to be replaced.
- The part number for the clock is AP4309072
- The part number for the latch switch is AP375254
Here are the break down diagrams for the Magic Chef range Model CGR3742CDC
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 05-22-2008, 11:16 AM
Junior Member
Default
Hi Gene,
When the door is closed, the latch will move all the way left to right (unlocked to locked) but still indicates "locked" on the display. When the door is open, the latch will not swing all the way from left to right. I apologize for my ignorance with all of this, so I sincerely appreciate your help.
  #4 (permalink)
Old 05-22-2008, 06:00 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check if the door latch handle is not bend and is properly screwed to the door latch. Check the latch switch for continuity.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Check heater circuit??? Sabra Dishwasher Repair 11 07-24-2008 09:14 PM
Open Door And Trips Circuit Breaker Docbuzzy Microwave Repair 1 04-11-2008 02:55 AM
door lock gpc52 Washer Repair 1 10-29-2007 05:04 PM
Washer door lock only jefflisa2 Washer Repair 0 08-26-2007 09:31 PM
Door will not lock hossross Washer Repair 0 08-25-2007 10:28 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
