2 Pages12>
bobirino
#1 Posted : Friday, February 26, 2010 2:14:56 PM(UTC)
bobirino
I cannot get a burner to light.
I have switched the potentiometers and the problem stays with the same burner that does not light...
What can i do next ..... thank you
P.S. this is one of the XLO burners:rolleyes:
#2 Posted : Friday, February 26, 2010 8:04:35 PM(UTC)
Does it click and/or spark when you turn it ON?
bobirino
#3 Posted : Friday, February 26, 2010 9:06:59 PM(UTC)
bobirino
yes it does click as do all of them. there is no gas going into the burner.
thank you for answering..........
#4 Posted : Saturday, February 27, 2010 2:35:34 PM(UTC)
Looks like the problem is a bad solenoid or a bad simmer control. You have to perform the troubleshooting as described in the attached file.
Here are the breakdown diagrams and Replacement parts for THERMADOR PRSG304 | AppliancePartsPros.com
File Attachment(s):
bobirino
#5 Posted : Saturday, February 27, 2010 3:56:12 PM(UTC)
bobirino
Thank you so much, I'm on the case and will let you know how things work out.....
bobirino
#6 Posted : Friday, April 9, 2010 4:49:32 PM(UTC)
bobirino
ok, and thanks for all of your help. now i have another situation in that i can not find the gas simmer control valve model #SQ003 for my oven/range.. any help out there? thanks in advance:rolleyes:
PS Thermador claims that they do not have this or a replacement for it....YIKES. what am i suppose to do? take it to the curb for trash pick up?
i think i found it thanks to gene. bosch ap3672574
bobirino
#7 Posted : Saturday, August 14, 2010 7:09:12 PM(UTC)
bobirino
Well I've finally had the time to replace the new simmer control and we have the same problem. What's next?
#8 Posted : Sunday, August 15, 2010 3:23:03 PM(UTC)
Have you checked the solenoid for this burner?
If you had, what was the result?
bobirino
#9 Posted : Sunday, August 15, 2010 5:24:46 PM(UTC)
bobirino
Can you send me a spec sheet to locate and check it. Any additional info would be helpful. Thank you, Bob.
bobirino
#10 Posted : Tuesday, November 16, 2010 2:10:35 PM(UTC)
bobirino
hey gene, what does it take to check the solenoid?
Kenmore Oven Bottom Burner Will Not Light (Oven Repair (including Ranges and Cooktops))
by kfost 3/6/2011 2:38:32 PM(UTC)
Magic Chef range oven burner will not light (Oven Repair (including Ranges and Cooktops))
by cdavis2260 10/14/2010 11:39:01 AM(UTC)
Gas dryer burner will not light (Dryer Repair)
by Mike Chapman 1/8/2009 11:26:58 AM(UTC)
Gas Oven Burner Will not light (Oven Repair (including Ranges and Cooktops))
by Matthew Wakefield 11/26/2007 8:00:10 AM(UTC)
2 Pages12>
