| » GE Built-In Oven F2 Code Oven Temps Erratic & Over-Temp |
Model Number: JKP15W0W2WW Brand: -brand- Age: More than 10 years
Hello and Thank you
Problem: I have a GE Built-In Cabinet Mounted Wall Oven. The Model # is JKP15WOW2WW, Serial #RS688956Q The Unit when started on BAKE Cycle will reach Pre-Set Bake Temp and will Signal Beep OK. Often, but not always, Oven will typically reach over-temp and throw an F2 Code Actual Temps (as set) will not be accurate as verified with Oven Temp Gauge and mostlt over temp by as much as +100 Degrees or more. I will also get this error on Clean-Cycle too. I see GE F2 indicates ERC Issue Questions: 1. Is this fixable and worth fixing? 2. Approximate Cost? for me vs Self-Repair 3. Does Oven or Just Front Touch Panel Assembly need to be removed? I am confident I can effect repair myself if I know what part will do the job. Thanks for your assistance Labor Effort Ads By Google Related Models |
| Display Modes | |
| Whirlpool Built in Oven Fault Code - E2 F3 | RockChalk | Oven Repair (including Ranges and Cooktops) | 1 | 01-03-2010 06:31 AM |
| Dacor Epicure wall oven error code L-34 Temp sensor | HDK | Oven Repair (including Ranges and Cooktops) | 8 | 12-21-2009 05:45 PM |
| bake temp runaway code on a kitchenaid oven | modemdog | Oven Repair (including Ranges and Cooktops) | 5 | 09-15-2008 01:53 PM |
| how to change oven door spring on a double oven that is built in | dick2256@hotmail.com | Oven Repair (including Ranges and Cooktops) | 0 | 04-25-2008 05:22 PM |
| Oven has two temps, off, and max 500 + | ocappe | Oven Repair (including Ranges and Cooktops) | 4 | 11-14-2007 05:31 AM |
