Discuss
Thermostate replacement
 in
My electric wall oven heats up to the desired temperature, and then turns off, and does not heat up again
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermostate replacement
  #1 (permalink)
Old 05-19-2008, 12:41 PM
Junior Member
nexparich is on a distinguished road
Default Thermostate replacement
Model Number: 9512wjv   Brand: Magic Chef   Age: More than 10 years
My electric wall oven heats up to the desired temperature, and then turns off, and does not heat up again to maintain desired oven temperature. I have replaced the heating element already. Could it be the thermostate?
The 11 year old oven has a thermostate with 4 prongs for wires to be plugged into it. The model number on the oven Magic chef (9512wjv) is not listed, or at least I can't find it. The computer suggests I check the model #9512wuv which has a thermostate with only 2 prongs for plug ins wires.
Should I keep rying to repair this, or just replace the oven ? Thanks
Ads By Google
Related Models
Magic Chef 9512WUA Walloven - Std Ele
Magic Chef 9512WUT Walloven - Std Ele
Magic Chef 9512WUV Walloven - Std Ele
Magic Chef 9512XUB Walloven - Std Ele
Magic Chef 9514WPA Walloven - Std Ele
Magic Chef 9514WPW Walloven - Std Ele
Magic Chef 9514XPB Walloven - Std Ele
Magic Chef 9522WUA Walloven - Std Ele
Magic Chef 9522WUV Walloven - Std Ele
Magic Chef 9522WUW Walloven - Std Ele
Magic Chef 9522XUB Walloven - Std Ele
Magic Chef 9524WPA Walloven - Std Ele
Magic Chef 9524WPW Walloven - Std Ele
Magic Chef 9524XPB Walloven - Std Ele
Amana 955.000 Mwave - Family Size (60 Hz)
Admiral 958AF-CLW Range - D/i Std Ele
Admiral 958AF-CLZ Range - D/i Std Ele
Admiral 958AH-CZW Range - D/i Std Ele
Admiral 958AJ-ZW Range - D/i Std Ele
Admiral 958WF-CLW Range - D/i Std Ele
Admiral 958WF-CLZ Range - D/i Std Ele
Admiral 958WH-CZW Range - D/i Std Ele
Admiral 958WJ-ZW Range - D/i Std Ele
Whirlpool 95LEGB5
Magic Chef 9612WUV Walloven - Std Ele
Magic Chef 9612XUB Walloven - Std Ele
Magic Chef 9614XPB Walloven - Cont Clean Ele
Magic Chef 9622XUB Walloven - Std Ele
Magic Chef 9624XPB Walloven - Std Ele
Amana 968.000 Range - S/c S/i Ddraft Gas
Amana 968.010 Range - S/c S/i Ddraft Gas
Admiral 968AF-C Range - S/c D/i Ele
Admiral 968AH-CHZW Range - S/c D/i Ele
Admiral 968WF-C Range - S/c D/i Ele
Admiral 968WH-CHZW Range - S/c D/i Ele
Amana 969.000 Range - S/c S/i Ddraft Gas
Amana 969.001 Range - S/c S/i Ddraft Gas
Amana 969.002 Range - S/c S/i Ddraft Gas
Amana 969.003 Range - S/c S/i Ddraft Gas
Magic Chef 96F-4CLW
Magic Chef 96F-4CLX
Magic Chef 96F-4CLX-19 Walloven - Cont Clean Ele
Magic Chef 96F-4CW
Magic Chef 96F-4CX
Magic Chef 96FA-4CLW Walloven - Cont Clean Ele
Magic Chef 96FA-4CLX Walloven - Cont Clean Ele
Magic Chef 96FA-4CW Walloven - Std Ele
Magic Chef 96FA-4CX Walloven - Std Ele
Magic Chef 96FN-4CLW Walloven - Cont Clean Ele
Magic Chef 96FN-4CLX Walloven - Cont Clean Ele
Magic Chef 96FN-4CW Walloven - Std Ele
Magic Chef 96FN-4CX Walloven - Std Ele
Amana 970.000 Range - S/c S/i Ddraft Gas
Amana 970.001 Range - S/c S/i Ddraft Gas
Amana 970.002 Range - S/c S/i Ddraft Gas
Amana 975.000 Mwave - Family Size (60 Hz)
Magic Chef 97F-4EVWW Walloven - S/c Ele
Magic Chef 97F-4EXWM9 Walloven - S/c Mwave Ele
Magic Chef 97F-4EXWW Walloven - S/c Ele
Magic Chef 97FN-4EVWW Walloven - S/c Ele
Magic Chef 97FN-4EXWW Walloven - S/c Ele
Frigidaire 98-1348-00-00 Tap(v1) / Upright Freezer
Frigidaire 98-1348-00-01 Tap(v2) / Upright Freezer
Frigidaire 98-1348-00-02 Tap(v3) / Upright Freezer
Frigidaire 98-1668-00-00 Tap(v1) / Upright Freezer
Frigidaire 98-1668-00-01 Tap(v2) / Upright Freezer
Frigidaire 98-1668-00-02 Tap(v3) / Upright Freezer
Frigidaire 98-1668-00-03 Tap(v1) / Upright Freezer
Frigidaire 98-2188-00-00 Tap(v1) / Upright Freezer
Frigidaire 98-2188-00-01 Tap(v2) / Upright Freezer
Frigidaire 98-2188-00-02 Tap(v3) / Upright Freezer
Frigidaire 98-2188-00-03 Tap(v1) / Upright Freezer
Amana 980.000 Mwave - Family Size (60 Hz)
Amana 980.001 Range - S/c S/i Ddraft Gas
Amana 980.002 Range - S/c S/i Ddraft Gas
Amana 980.003 Mwave - Family Size (60 Hz)
Magic Chef 9814VPV Walloven - S/c Ele
Magic Chef 9814XPB Walloven - S/c Ele
Magic Chef 9815VUV Walloven - S/c Ele
Magic Chef 9815XUB Walloven - S/c Ele
Magic Chef 9824VPV Walloven - S/c Ele
Magic Chef 9824XPB Walloven - S/c Ele
Magic Chef 9825VUV Walloven - S/c Ele
Magic Chef 9825XUB Walloven - S/c Ele
Magic Chef 9834XPB Walloven - S/c Mwave Ele
Magic Chef 9835VVV Walloven - S/c Mwave Ele
Magic Chef 9835XUB Walloven - S/c Mwave Ele
Magic Chef 9835XVB Walloven - S/c Mwave Ele
Magic Chef 9844VPV Walloven - S/c Ele
Magic Chef 9844XPB Walloven - S/c Ele
Magic Chef 9845VUV Walloven - S/c Ele
Magic Chef 9845VVV Walloven - S/c Ele
Magic Chef 9845XUB Walloven - S/c Ele
Magic Chef 9845XVB Walloven - S/c Ele
Magic Chef 9854VPV Walloven - S/c Ele
Magic Chef 9854XPB Walloven - S/c Ele
Magic Chef 9855VUV Walloven - S/c Ele
Magic Chef 9855VVV Walloven - S/c Ele
Magic Chef 9855XUB Walloven - S/c Ele
Magic Chef 9855XVB Walloven - S/c Ele
Magic Chef 9864VPV Walloven - S/c Mwave Ele
Magic Chef 9864XPB Walloven - S/c Mwave Ele
Magic Chef 9865VUV Walloven - S/c Mwave Ele
Magic Chef 9865XUB Walloven - S/c Mwave Ele
Magic Chef 9875VRV Walloven - S/c Ele
Magic Chef 9875VVV Walloven - S/c Ele
Magic Chef 9875VYV Walloven - S/c Ele
Magic Chef 9875XRB Walloven - S/c Ele
Magic Chef 9875XVB Walloven - S/c Ele
Magic Chef 9875XYB Walloven - S/c Ele
Magic Chef 9876VVV Walloven - S/c Ele
Magic Chef 9876XVB Walloven - S/c Ele
Amana 988.000 Mwave - Family Size (60 Hz)
Amana 988.010 Mwave - Family Size (60 Hz)
Amana 989.000 Range - S/c S/i Ddraft Gas
Amana 989.001 Range - S/c S/i Ddraft Gas
Amana 989.002 Range - S/c S/i Ddraft Gas
Amana 989.003 Mwave - Family Size (60 Hz)
Magic Chef 9895VRV Walloven - S/c Mwave Ele
Magic Chef 9895XRB Walloven - S/c Mwave Ele
  #2 (permalink)
Old 05-20-2008, 01:13 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Call the Appliance Parts Pros customer service (877-477-7278) and ask for Adam.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Tub Replacement CLOMJM Washer Repair 2 04-11-2011 05:10 PM
how to change the thermostate on my whirlpool dishwasher chiefrosy Dishwasher Repair 1 02-22-2010 05:10 AM
High Temp thermostate question mr_rabbit_58 Dryer Repair 1 05-12-2009 05:37 AM
Saftey Thermostate LISA TEUTSCH Oven Repair (including Ranges and Cooktops) 1 12-16-2008 06:24 PM
How do I replace a temp. thermostate Ev1Vargas Refrigerator & Freezer Repair 1 12-05-2008 08:40 PM
